325i ca 325e engine visual differences
  • steelynorm
    • Jun 2010
    • 100
    Looking at purchasing a 1987 325
    Cluster was swapped by PO, cluster is an I cluster(6k redline)
    How to tell if it’s an e or an I engine?
  • JasonC
    Site Manager
    • 14451
    Assuming that nobody did a swap of any kind. Just by glancing at it the intake is different and valve cover too. The e will have a cold start valve on the pass side of the intake. To where the I dont.
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • jeffnhiscars
      • Jun 2011
      • 6011
      The e will also have 2 reference sensors going to the divers side of the bell housing and connecting at a bracket lower block near the starter
      Alice the Time Capsule
      • Originale30
        • Sep 2017
        • 165
        Also the coolant expansion tank is different and different location with the e to i engine bay locations
        • jeffnhiscars
          • Jun 2011
          • 6011
          That's actually a reflection of the year not the engine type.
          • McGyver
            • 4637
            Correct. The expansion tank was moved in 9/1987.
            • kickinindian
              • 2327
              easy one that i tend to look at first is the placement of the ICV.
              the Etas are on the passenger side of the intake and the I one is located right before the throttle body on the drivers side of the intake.
              • ForcedFirebird
                • Feb 2007
                • 8300
                The engine blocks are identical, not easy to tell what rotating assembly is in there, BUT, the head casting number is a dead give away. Difficult to see, but it's located in the center of the head, driver side, directly between #3 and #4 intake runner, just below the valve cover. If it ends with 200, it's a full 325e engine as the 325i rotating assembly absolutely cannot work with an eta head. If it's an 885 head, you may have a "hybrid" type 327i combination.
                john@m20guru.com
                Links:
                • Melon
                  • Mar 2018
                  • 1311
                  M20B27
                  M20B25
                  I do things.
