s50 Rods in m20
  • Andre3127
    • Dec 2017
    • 291
    s50 Rods in m20
    Well, some S50 rods may have fell into my lap.
    Is there anything I should know before throwing them into my m20? I assume standard S50 rod bearings will work without any problems? What kind of power numbers will they hold before being ejected from the block?
    I figure they should be a direct upgrade, but I figure I should ask just to double check.
    Budget E30 Parts - Used and Reconditioned parts for your BMW
  • E30-325iS
    • Sep 2011
    • 191
    You'll need new rod bolts as well.
    I'd imagine they would handle at least as much power as the S50 made.
    What else are you doing to your engine?
    • Andre3127
      • Dec 2017
      • 291
      Rod bolts are a given.
      Engine is getting a stock rebuild until I blow it up, then I'm building a 2.8 or 2.9 stroker. On the 2.5 setup I'd like to push 350 wheel. I just don't want to throw a rod through the block.
      • TobyB
        • 5287
        What part of "blow it up" DOESN'T involve a rod thru da block?
        t
        pushing a 15" wheel
        • digger
          • Nov 2005
          • 6193
          turbo S50 make more than that. like everything just needs to be properly tuned and itll be fine
