Engine ID Help
  • gilber33
    • Jul 2012
    • 244
    Engine ID Help
    Hello:
    I'm just trying to id an engine I bought. All of my searching has told me to look at the numbers on the machined flat spot by the dipstick. However, I do not have a flat spot there, it's on the other side of the engine mount. And it doesn't have the series of numbers and letters like everything I found said it should. See the pictures:
  • e30davie
    • Apr 2016
    • 1788
    Google that number next to "bmw"
    • DaWildBeast
      • Mar 2016
      • 244
      Engine ID Help
      1289 575 is an i block
      BMW engine and powerplant identification codes decoded: understand M20, M30, S14, S50 and the full BMW engine naming system.
      • gilber33
        • Jul 2012
        • 244
        1289575 isn't anywhere in that book under the m20 section.
        Is it unusual that the block only has that one number in the flat spot and not all the other codes?
        • DaWildBeast
          • Mar 2016
          • 244
          Maybe this thread will help
          • digger
            • Nov 2005
            • 6215
            you can tell from the pistons
            • TobyB
              • 5298
              yeah, casting numbers don't really tell you much about what the block was machined into-
              looking at things like pistons, where the CPS is, casting number on the HEAD,
              how many bearings the cam has,
              etc, tells you a lot more.
              t
