Dreaded white smoke?
  • chrisracer79
    • Nov 2013
    • 25
    I purchased a 'rebuilt' M20B25 about 6 years ago from someone whom I'd done business with before. I just got around to firing the engine for the first time today, and I immediately get white smoke coming out the rear. Immediately.
    I haven't had a chance to run the car long enough for it to warm up. Will do that this weekend.
    Before I panick and I think I've got a blown head gasket or a cracked head, is it possible that water and/or coolant has seeped into the engine after sitting for at least 6 years (possibly longer)? Or could it be something else since it happens immediately when trying to start the car?
    I filled the coolant system with distilled water for now. There could be some original coolant left in the engine but I can't be sure.
    Video is attached. Please excuse the current state of the car. Swap in progress!
    White smoke vid
  • Danny
    • 14216
    Yeah let it warm up. If the headgasket is bad its not like you'll make it any worse.
    • Gregs///M
      • Mar 2012
      • 2459
      I would not worry about smoke coming out of an engine that hasnt been ran for 6 years. Run the motor for a while and start it up again the following day, if a significant amount of smoke appears then be worried about coolant getting into combustion chambers.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • chrisracer79
        • Nov 2013
        • 25
        Ok. Hopefully tomorrow I’ll get a chance to smoke out the neighborhood. :)
        Another related note. I’m having a hard time keeping the car running at the moment. I have to keep turning the key and opening the throttle to get it to run. Car dies when I stop turning the key. However this seems to be getting better each time I try starting the car. Maybe Another symptom of sitting idle for a very long time.
        • jeffnhiscars
          • Jun 2011
          • 6011
          I'll just add that, if it has sat for that long you should replace the timing belt before running it any more. I know it's a pain when you're not sure of the engine condition but it beats busting a rocker or head.
          Why not do a compression and leak down test first.
          Alice the Time Capsule
