So If I Have A Full Super ETA Engine...
  • Ben Carufel
    • Jun 2004
    • 5248
    What parts do I need to make a stroker? I've heard stuff for years about putting some super ETA parts with "i" parts and coming up with an oem-parts stroker, but I've never researched it at all.
  • digger
    • Nov 2005
    • 6075
    to stroke a 2.7 you need a bigger crank but thats just a technicality.
    i believe double valve springs are one part thats recomended
    • pdx 528e
      • Jun 2006
      • 33
      You need some parts from a 325i:
      at minimum:
      cylinder head, ECU
      recommended:
      intake manifold, injectors, FPR, AFM, throttle body, exhaust system
      This only works for super eta engines, not standard etas.
        • 34839
        you don't need a new cylinder head, the super ETA has the same head casting as the 325i. all you need are dual valve springs, an i cam, and drill the oil journals for the 7 bearing i cam. best replace your rocker arms and eccentrics while you are at it, plus probably new valve guides and a good valve job.
        • erik325i
          • Jan 2005
          • 3567
          How is this a stroker? He is still using the stock crank, therefore his stroke is the same. The displacement is staying at the stock 2.7L...
          He is simply changing a cam and valve springs, not building a stroker.
          -Erik
          • pdx 528e
            • Jun 2006
            • 33
            Yes, referring to this setup as a stroker is a misnomer but its the same end result as those with 325i's who actually do stroke their motor with an eta crank. I wasn't going to split the hair.
            I would think its less labor intensive to slap on a good 885 head than actually have the head drilled for the extra cam journals, etc. The head already has to come off to drill and change cams, just work with a 325i head for less downtime.
            • SpecM
              • Oct 2005
              • 4531
              -The exhaust sytem and DME systems are the same. You just need a stock 325i chip... or just get and aftermarket one. And go ahead and go for 19# injectors and a m30 AFM.
              1989 cirrisblau-metallic 325i
              • pdx 528e
                • Jun 2006
                • 33
                This is great news regarding the ECU. Is there a resource that mentions this? One less part I need to buy.
                • C ///M
                  • 1040
                  To help clarify, this is exactly what you need to do. This will yield a "2.7l i stroker".
                  In addition, you'd simply need an "i" chip. I'm pretty sure that '88's and up used motronic 1.3, so you should just pick up a 173 "i" chip and call it good.
                  **Did a quick search, not sure if super eta's used motronic 1.1 or 1.3. If I had to do it, I'd just pick up a complete 173 325i DME and throw in a conforti chip**
                  332iS R.I.P.
                  • Jand3rson
                    • 37587
                    If I'm not mistaken, you'd also need a 325i intake manifold and throttle body, correct?
                    Chris is correct here. I'm not sure of the Motronic system that the s-eta used, but i know that they used an ECU ending in 154, which Conforti did not make a chip for. In order to get the best (OEM) engine management, you would need the ECU from a 1.3 car, with a 173 ECU.
                    • PУCCKAЯ_e30ka
                      • Jan 2006
                      • 1226
                      ok... i think these are essential!
                      t-body
                      intake mani
                      i-head (without the mastrubation of supere head drilling blah blah...)
                      ecu
                      injectors
                      following would be plus+
                      exhaust
                      afm
                      headers
                      afpr
                      chip
                      even better plus+
                      rebuild head with little higher comp and smoothed/worked
                      • C ///M
                        • 1040
                        Josh is right, you need the intake manifold and throttle body as well.
                        The super eta, as already mentioned, already comes with an "i" head. It simply uses an eta cam with single valve springs. You need to pick up an "i" cam and dual valve springs and have the additional oil journals drilled.
                        Summary to convert super eta into 2.7liter "i" motor:
                        -"i" cam and dual valve springs with additional oil journals drilled
                        -"i" intake manifold and throttle body
                        -"i" center section (dual pipe after cats) and muffler (the exhaust manifolds are the same)
                        -"i" 173 ecu and chip
                        With the switch to the 173 ecu, I'm not sure what goes on with the fuel injectors. I know "i" injectors and "eta" injectors were different. (low impedance vs. high impedance.)
                        332iS R.I.P.
                        • Jand3rson
                          • 37587
                          You would need the 325i fuel injectors.
                            • 34839
                            -Erik
                            I never said anything about a stroker in my post ;)
                            • SchnellerVert
                              • Sep 2005
                              • 3948
                              Ben did thou.
