I don't know if the chip is any different, but the Mahle catalog lists specific pistons for the "M20B27 mtech." They are domed, and look more like B25 pistons than eta pistons, so the pistons must be different.
how much power can u get with the cheap stroker?
In South Africa we also had factory 2.7 models called 325is. The 325is Evo II was rated at 155 KW (210 hp).
I posted some pics of 325i and the 2.7 Mahle pistons as well as profile comparisons on our South African forum.
The 2.7 engines use the 135mm conrods. The gudgeon pin is higher up in the piston to compensate for the increased stroke of the crank.Comment
Super Eta piston compression w/ the 885 head is 8.5:1. I made a 327i (2.7L which is what an eta has stock) out of my Super Eta by carrying all the "i" components over. Metric Mechanic states that this is good enough for ~170-180hp and good for ~100K miles when driven hard. I'd say it pulls much better then a stock super eta. I have a 3.25:1 LSD on it as well that helps with pulling. Stock w/ the 3.25:1 LSD made it an even race to 60mph w/ Andy's Euro 1986 325is.
Now that it is a 327i, who knows. ;)
-ChrisComment
