Who makes a 284/272 cam?
  • eugeman
    • Sep 2007
    • 306
    And where can I find it?
  • digger
    • Nov 2005
    • 6213
    dbilas, schrick which are the same specs for lift, timing, duration, lash.
    • Hadrian
      • 48
      Exactly the same? Is one better than the other?
      • digger
        • Nov 2005
        • 6213
        the specs provided are identical for both but that doesn't mean the profile can't be slightly different but the difference between the two (if there is any) would be neglibable
        • eugeman
          • Sep 2007
          • 306
          When I see vendors advertise a 284 cam is that the same one? None of them mention that it is 272 (split duration) on the exhaust!
            • 34847
            probably not.
            also, MM makes a similar cam (dual pattern). not sure how it compares to the schrick, could be more aggressive.
