Can anyone suggest rods?
  • sark
    • Dec 2004
    • 42
    Anyone have any suggestions about who makes the best lightweight rods? I dig the korman ones but something tells me they won't be cheap!
    Thanks!
  • CarsSuck
    • Oct 2005
    • 968
    Im gonna bump this because im beginning to think of how im gonna build my m20.
    Whats the deal with S50/52 rods? Dont all the m/s50 engines use 135mm rods? So how good are the benefits?
    --Will
      • 34847
      M52 and S50/S52 rods are all quite a bit lighter (80-100grams each) than M20 rods. the M52 are probably the strongest of the bunch, while the S50 are the lightest. And yes they are all 135mm. I paid $300 for a set of S50 rods.
      you can get eagle H-beam forged rods for about $550 a set - they will be both stronger and lighter than the S50/M52 rods, and you can get them in whatever length you wish.
      • eugeman
        • Sep 2007
        • 306
        How heavy are the stock m20 rods?
          • 34847
          ~665 grams
          • eugeman
            • Sep 2007
            • 306
            I would like to lighten my stock rods and was told if I use the angle grinder I should grind in the direction of the rod motion, has anyone heard of this before? Also what is a safe weight I can bring each of them down to?
            • digger
              • Nov 2005
              • 6216
              yes, thats so the grinding tool marks are parallel to the principal stress direction which is less likely to produce a fatigue crack than having the tool marks transverse.
