so, can i buy a chip destined for a 2.5 and run it>? or it plays to greatly with the mix?
1.3 Motronic Up-Grade & 2.7i How To
This is a sticky topic.
This.
It's really about how far you take your 2.7i. If done correctly and you use the 885 head with intake, TPS, TB, wire harness etc, etc... on the ETA 2.7L block and internals, you would inevitably have to replace the ECU with one from an "i". So the chip you would use would be a 2.5 "i" (or 173 ECU) Chip.
Then boost it.Need a part? PM me.
Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Comment
^It turns it in to a whole new monster ;)
1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)Comment
sigpicComment
e harness is trash period. :)
The e harness runs flywheel sensors and the i harness runs front crank sensor, no way to rig it....
So I'll need the CPS and timing wheel for the front. Other than that, are there any other sensors that need to be swapped out?sigpicComment
One more time, haven't seen a direct answer to this really. My 87 325is car and head swapped on a 2.7 eta block will run okay? I have the chance and parts to do this and want to turbo later on, drive for a year N/A, would it be okay, computer etc...Comment
That question has been documented all over the Internet and forums, you just need to search. Yes you can put an I head on an e block, yes it will run okay, yes you will have stupid low compression which is okay I guess if you plan to turbo, and yes you will have an unmatched piston/combustion chamber design.Old and improved:
