Performance Cam Question-
  • Eviltwin
    • Mar 2008
    • 323
    Looking for a aftermarket cam for my stroked M20-
    288 too aggresive, looking to stick with a 272 in order to use stock ECU with proper fueling, (chipped)
    My question is, The Shrick 272 is pushing the $600 mark...
    however, I find Ireland Enginering Cams for less than $350...
    is the difference thagt remarkable?
    opinions?
  • digger
    • Nov 2005
    • 6213
    opinions?
    in all honesty its probably not but unless IE give you some decent specs to look at and compare with the schrick look elsewhere. Atleast with the schrick you'll know what you're getting.......its better tthan a stab in the dark.
    • AndrewBird
      The Mad Scientist
      • 11898
      I believe the IE one is a reground cam where as the Shrick is not. That complicates things when comparing them directly.
      Personally, I would never buy a regrind, but I will agree $600 is a bit much.
      • Eviltwin
        • Mar 2008
        • 323
        I'm a little confused by the term "regrind" is it essentially the same as a 'rebuild'?
        where a customer would sent their core piece in, and wait for they're new cam?
        is anyone running a IE 272 cam?
          • 34847
          they grind down the base circle in an attempt to increase the duration and lift
          it "works" but there is more to cam than peak lift and duration - you're not going to get a lot from a regrind.
          • surebimmer
            • Jan 2004
            • 978
            I would recomend a CAT cam from flyingbrickperformance.com They used to have a 272 cam that was more aggressive then a Shrick. DOn't see it list on there site now but email and see if you can get one. Also with a regrind you'll need oversized ecentric's to adjsut valves and this add's to the cost of the cam.
            • Eviltwin
              • Mar 2008
              • 323
              oh nice-
              thanks for the lead Surebimmer-
              I'll def. be calling them up to see if catcam still manufactures a 272-
              Prices seem descent aswell
