Hey Guys,
I have done alot of research on alot of the forums but I havnt come down to a definite answer.
I currently have an 1990 e30 325is with a that was converted to a 2.7 stroker. This being said, I wanted to do the M30 AFM with the 19lb injectors. This will be running on a K&N filter in the stock airbox. Do you guys feel like this is the correct route to go? considering the stock injectors (14.5lbs) are not even adequate for the 325is engine.
Thanks,
Chris
Thanks,
Chris
