M20 AFM to M30 AFM with 19lb injector questions
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    #121
    Originally posted by nurseklb
    is this mod worth it with an eta?
    no
    • nurseklb
      • Nov 2008
      • 36
      #122
      what can be done to an eta thatwill make a noticeable difference?
      why does it have to be a "dead end"? why not just "end"?
      • CorvallisBMW
        • 13039
        #123
          • 34847
          #124
          replace the engine with something that makes more power. ;)
          seriously, just get a chip. It makes a huge difference on the eta, but that's about all there is. Other "upgrades" are more likely to hurt than to help.
          • FRODADDY
            • Feb 2012
            • 144
            #125
            Sorry for pulling up this old story.
            I bought new design lll 19lb injectors and the 027 M30 AFM.
            My engine is a 88 Supereta with i head and SSSquid 327i 14.5lb chip.
            If I am not wrong I should be good with my chip, right?
            Am I also right that I do not need to adjust the AFM?
            Thanks!
            1990 kashmir beige BMW e30 327i
            1993
            muggello rot BMW e36 M3 Gruppe A Euro
            1990 GP weiss Porsche 964 C2
            1997 schwarz II BMW e36 328iS supercharged
            • sayed ali
              • 762
              #126
              Thanks!
              I'm not sure if that chip will suit your setup since it's designed for 14.5lb and you're running 19lb .. also you may need few changes in the AFM, better to have a afr gauge ..
              M20B28 Turbo
              My Build Thread
              http://www.r3vlimited.com/board/showthread.php?t=255839
              • FRODADDY
                • Feb 2012
                • 144
                #127
                Thanks!
                That's actually what I figured too.
                1993
                • mazzo
                  • Jul 2014
                  • 264
                  #128
                  Don't you need to upgrade your ECU at the same time because the mapping will be different with your upgrade?
                  Current:
                  '88 325ic Silver 5sp
                  '17 Subaru Outback 3.6R
                  Past:
                  '14 Rav4 EV (with tons of torque!)
                  '06 325i Black 5sp
                  '02 S4 Avant Black 6sp
                  '00 Boxster Silver 5sp
                  '98 New Bettle Yellow 5sp
                  • FRODADDY
                    • Feb 2012
                    • 144
                    #129
                    So I also ordered a new ECU fro SSSquid.
                    As I am already very happy with his current chip I am curious how it will perform with the new one.
                    1993
                    • AlphaE
                      • Sep 2011
                      • 503
                      #130
                      Thanks!
                      I am VERY curious about how this will work for you. I have a 88 seta swapped to I w a 173 stock ecu. No chip. greend top inj. idle comes and goes. some days silky smooth other days rough. seems to be rich. Always runs great through the RPM though. sounds like an 027 afm would help. Hows the SSSquid chip? and hows the M30 afm working on it?
                      Now with 2.7i power!!!
                      • Dirty325ix
                        • Sep 2012
                        • 689
                        #131
                        So is every m30 am a 027
                        If not is there a way to tell the difference?
                        • binnavert
                          • Apr 2015
                          • 31
                          #132
                          Where do I locate part number?? Searched for any numbers with enough digits,none were found. TIA
