mill m20 heads
  • sl0ride
    • 154
    mill m20 heads
    I have an extra M20 head,. Anyone have any info on how much i can mill off them to bump up the Cr without fuckin up the heads?
  • SpecM
    • Oct 2005
    • 4531
    not much... maybe .010" tops?
    1989 cirrisblau-metallic 325i
    • XvillainousX
      • 176
      Did you ever mill your head? If so, by how much? In my youth I milled my integra head 0.060 and enjoyed it. I'm also curious as to how far we can mill the M20 heads before the valve hit the pistons.
      • moatilliatta
        • 6158
        I think its .027 maybe....
        @Zakspeed_US
        • Knockenwelle
          • Jul 2008
          • 395
          There are three cast-in "dots" in the deck surface, about 5mm diameter. Those are the service limit indicators, so don't go past those. It's hard to state a number, cause you rarely know the whole history of a head. As far as P-V, you'll just have to measure it. Running a stock i cam shouldn't be a problem at the maximum cut depth. I found that with mine decked to within .004" of the dots, my cam timing changed about 3 deg, so keep that in mind. However, running the big Schrick, the compression bump is a welcome addition.
          Mike
          '91 325i track car. Mostly...
          • StereoInstaller1
            GAS
            • 22679
            I have heard there is someone out there making an adjustable cam sprocket
            Closing SOON!
            Thanks for 10 years of fun!
              • 34847
              there are 3 that I know of, they cost between $150-$200.
              • StereoInstaller1
                GAS
                • 22679
                Any links?
                Closing SOON!
                • akorcovelos
                  • Dec 2006
                  • 1149
                  I know I have seen one guy on ebay selling them.
                  2012 MCSCC/NSSCC CP class champ
                  HSAX Instructor
                  • eugeman
                    • Sep 2007
                    • 306
                    My understanding is 0.1mm shaved = 0.1:1 increase in compression as a general rule of thumb on the M20. You would really have to measure the total volume to get an accurate final of how much your compression has increased after shaving. I believe the max amount one can shave on an unmolested cyl head is 0.4mm before it becomes scrap metal. But again you would have to measure the height of your existing cyl head material before shaving, to see how much farther you could go.
                    I bought one of these, and my initial impression is that is of decent quality though I have yet to install it:
                    http://cgi.ebay.ca/BMW-Adjustable-Ca...3A1|240%3A1318
                    • Kingb
                      • 928
                      How much was that in Dollars? i am about to have my head milled due to overheating and a blown HG. So shouls I get it milled a little more than just to level it out.
                      Do you have to do anything else like run highre octane gas or anything??
                      Originally posted by Nicademus
                      My car beats off to that car. :bow:
                        • 34847
                        overpriced junk, that's merely a stock cam gear that's been cut up and a plate bolted to it. You can get one CNC machined from PPF for about the same price or maybe even less. I don't have a link but there is a thread on E30tech in the engine management section that does, it's called something like "cam sensor options for the M20".
                        • Kingb
                          • 928
                          Any links?
                          Just saw this on Ireland and is cheaper than the one on ebay
                          http://store.nexternal.com/shared/St...t=products.asp
                          • eugeman
                            • Sep 2007
                            • 306
                            Wow, that looks like the exact same piece of overpriced junk as the one that I've got. I'm glad I only paid $130cdn for mine. ;)
                              • 34847
                              hey, I almost bought one for $60. But I'm not sure how much I'd trust the thin webbed part of the OEM gear at 7200rpm, after it has been cut in half, drilled/tapped with screws threaded into it and only 1-2mm of material left on each side. it may have been worth the price at $50-60, but definitely not over $100.
