What Head Gasket?
  • Dyno4mance
    • 345
    What Head Gasket?
    I am nearing completion of a high compression (11:1) head build and I am wondering what head gasket would be the best to use..
    I have ARP head studs and was planning on a HG that was the stock thickness or close to it so I can maintain good quench
    Metric Mechanic sell a modified water passage one that apparently stops the head cracking on #5 Cam tower it is quite pricey at @$200.00...does anyone know if the gasket they sell is a "Multi Layer Steel" or just a modified stocker?...and if it is any good
    Also they have a modified spray bar with smaller diameter oil passages to stop too much oil getting to the head...Is this piece worth the money?
    Thanks in advance...
    2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
  • Dyno4mance
    • 345
    Wow....has no one tried the Metric Mechanic HG?
    19 vews and no replies....
    • guibo09
      • Dec 2008
      • 834
      im curious to where this goes to
      90 E30 325i
      • Dyno4mance
        • 345
        ^^^^^^apparently no where....
        • Dyno4mance
          • 345
          53 views!!!and not even a snide remark....
          Does anyone on this site even own an e30?:mrgreen::mrgreen::giggle:
            • 34844
            stock HG will be just fine. Turbo guys use them all the time with ARP studs, 11:1 CR is nothing in comparison. :)
            • akorcovelos
              • Dec 2006
              • 1149
              If you want peice of mind get the head welded, costs about the same as the MM HG. Otherwise stock equipment is fine for any N/A M20.
              2012 MCSCC/NSSCC CP class champ
              HSAX Instructor
              • guibo09
                • Dec 2008
                • 834
                if stock equipment is fine on an N/A m20, why do so many N/A m20's crack their heads?
                90 E30 325i
                  • 34844
                  because BMW coolant systems are picky and people overheat them. that has little to do with high CR or RPMs..
                  • guibo09
                    • Dec 2008
                    • 834
                    so what is the recipe for a crack free head besides running the MM gasket?
                    90 E30 325i
                      • 34844
                      don't overheat it.
                      the reason people weld the coolant channels isn't to prevent cracking, it's because the head flexes a lot around the huge (and uneccesary) channels which causes the gasket to unseat and eventually blow. Although that could lead to cracking, it's not the main purpose.
                      • digger
                        • Nov 2005
                        • 6194
                        you can make any OEM goetze gasket a MM one with a dremel and 10sec.......all they do is elongate a couple of holes to the "teardrop" shape.
                        • Dyno4mance
                          • 345
                          So the general consensus is stock will do even on a race engine...?
                          so, I should not even consider the MM, the IE MLS or the Vac race gasket then..?
                          Thanks for the responses...
                            • 34844
                            I wouldn't even consider an MLS on an N/A engine.
                            plus you have studs - a good quality OEM headgasket and the proper torque on those puppies is all you need. and of course good tuning and proper cooling system maintenance. I'm guessing you're not going to try and use the stock chip/ecu with an 11:1 CR race motor, so no worries about a poor tune causing problems. :)
                            • Dyno4mance
                              • 345
                              That was the answer I was initially looking for, So the mm piece is just made of stock material....?
                              Then because of this modification I would think that logic would suggest welding the head would compound the head cracking problem...No?
