What Head Gasket?
    • 34844
    I don't know if I buy jim's theory on that one or not. Lots of people have the head welded and never have problems with cooling. BMW actually made the same design change on later M30 heads.
    • Dyno4mance
      • 345
      Originally posted by nando
      I wouldn't even consider an MLS on an N/A engine.
      plus you have studs - a good quality OEM headgasket and the proper torque on those puppies is all you need. and of course good tuning and proper cooling system maintenance. I'm guessing you're not going to try and use the stock chip/ecu with an 11:1 CR race motor, so no worries about a poor tune causing problems. :)
      I will eventually use MS as engine management...everything is new on the motor and has cost over $5000 to build....I am however going to experiment on the dyno during break in using race gas with the stock motronic as I feel even with the added CR the race gas will have enough octane to keep det at bay...and hopefully make a lot more power without changing a thing...
      2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
      • Dyno4mance
        • 345
        I tend to agree with you....
        What do you think of the spray bar mod they have going?
        • digger
          • Nov 2005
          • 6195
          Originally posted by Dyno4mance
          That was the answer I was initially looking for, So the mm piece is just made of stock material....?
          Yes, they are Goetze.
          • Dyno4mance
            • 345
            Do you have aMulti layered steel gasket on your e21?
              • 34844
              potentially a good idea if you are going to be spinning it high in the RPM range for long periods of time. the M20 head tends to fill with oil quite rapidly. I don't know about on a daily driver or a car that sees low RPM/idle very much. At the very least, i would get a new one and make sure it's not bent or spraying in the wrong direction.
              • digger
                • Nov 2005
                • 6195
                i have a standard goetze in my E30 which is my only car.
