overheat light on check panel illuminates all the time
  • DaveSmed
    • Apr 2007
    • 1407
    I could be mistaken, but if memory serves, thats a catalyst temperature warning.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • NeoMishMoo
      • Jul 2009
      • 448
      Originally posted by ADEN
      i'll try to replace the engine if it'll turn it off.
      Don't go to that extreme just do what Erik says.
      Originally posted by erik325i
      Just pull the bulb out of the check panel for that one.
      Erik
      That actually might be too much trouble having to pull out the snapped in check box, then twisting a bulb... just get a little black electrical tape! It wouldn't be the first time I've seen it. (most people use that as a quick fix to "check engine" light)
      West German BMWs, they just don't make the same as they did before the wall fell.
      ^Case in point: Auto-Repair Technology. Everytime my car isn't starting or acting up I let it sit, sometimes for an hour, sometimes for days. But it eventually fixes itself.
      • Court M3
        • Jan 2004
        • 6713
        1. States read manual before driving
        2. When lamp is on drive under 50Kph. After car is parked turn off engine if light stays on or if light keeps coming back on bring it to dealer to have them check it.
        3. Make sure not to park the car near any flammables because hot exhast gases could ignite them.
        Continuous For Sale Thread
        323i s50
        • ADEN
          • 620
          court i love you
          • bmwmotorrad
            • Nov 2008
            • 32
            Alright, just an update on the thread. The light is related to the cat exhaust temp (required Jap law) and is a DME related fault. I hooked up to the GT1 today but there were no DME faults stored. This may be due to the fact that it is a Jap/ECE market vehicle and I am using a USA GT1.
            Anyway, I will try some bootleg software to address the fault and try to clear it. If I can and it returns, I will then check the actual cat temp(specs anyone?) to see if there really is an issue or if its just the sensor($175 btw).
            I usually am not one to "pull the bulb" but I may if it is sensor issue.
            More to come....
            • jpntrng
              • Jan 2016
              • 3
              More to come....
              What did you end up doing? Pull bulb, reset something or replace sensor?
              I have the same thing on my Touring which is also from Japan. Car had bad misfire when I first got it and the overheat light would go off and on. Now after fixing misfire (new plugs, OEM wires, Bremi cap & rotor) along with new ICV car runs beautifully but light is on all the time.
              • 101
                • Jul 2011
                • 764
                If your oxygen sensor is older or malfunctioning, it could be causing the engine to run too rich - which is going to make the cat run at a higher temperature.
                I had a similar circuit on a late 70's Fiat, except it said "SLOW DOWN".
                Just food for thought.
                101
                The E30 collection:
                1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                1987 325is - Delphin / Black Sport (son #3's)
                1987 325i Convertible - Triple Black
                1989 325iX Coupe - Diamondschwarz / Black Comfort
                1990 325iX Coupe - Sterling Silver / Grey Sport
                1981 Fiat 124 Spider 2000 - Green / Tan
                1998 Volvo V70 GLT - White / Tan
                1998 Volvo S70 T5 manual - White / Taupe
                2001 Ford Windstar - Silver / Grey (parts hauler)
                2006 Lexus GX470 - White / Tan (tow rig)
                • TobyB
                  • 5293
                  a late 70's Fiat, except it said "SLOW DOWN, PARTS FALLING OFF".
