A few rebuild questions on E bottom end
  • i_build
    • Oct 2015
    • 52
    Long and short is that I have a 325is with a bottom end that was in bad shape so I got a hold of an E bottom end that was in good shape and put new rings and bearings using the rest of the E bottom end (crank, rods, and pistons)... but I have a few questions on final assembly.
    The 85 E vibration damper is different than the 87 i... and the donor E crankshaft sensor that was different than the i. I am running MegaSquirt and recall during initial setup there were some tooth settings for timing but the E looks to have no teeth (or dentures either). I don't know if I could just use the toothed damper from the i and bolt it to the E crank and use the i crank sensor... or whether I have to use the E damper and E sensor and what ramifications that has on MS?
    Of less importance... I have a extra new camshaft seal and would like to know if they are the same as the intermediate shaft seal as I need to replace mine (looked for size but can't find it) If by chance anyone knows please let me know otherwise will just order one new.
    Thanks in advance for all the help.
  • e30austin
    • 15382
    You need to run the front balancer and crank position sensor bracket from the B25 engine - I would recommend buying a new crank position sensor for your engine. FWIW, the B27 gets its engine speed information from the reference sensors on the flywheel, while the B25 gets it off the front balancer. Good luck.
    • i_build
      • Oct 2015
      • 52
      Thank you will do.... and as a side not the seal for the camshaft is the same size as the intermediate shaft after pulling out the old magnifying glass.
      • digger
        • Nov 2005
        • 6140
        curious why you put new rings and bearings in the eta bottom end instead of the 'i' one? or a mix and match stroker
        • i_build
          • Oct 2015
          • 52
          My I piston rings on 2 cylinders gave way under boost and looked to be in rough shape. Rather than risk it I used the eta pistons. I know my compression takes a hit but I rather that than have issues with the i pistons.
          • digger
            • Nov 2005
            • 6140
            Fair enough of its got metal escargot
            • Andre3127
              • Dec 2017
              • 291
              The 325e ran off a different system than the 325i engine. The only b27 things you want are the pistons, rods, and crank. Use b25 parts from the original engine for everything else.
              Budget E30 Parts - Used and Reconditioned parts for your BMW
