m20 stroker engine; headers smoking:(
  • 2002jm
    • Sep 2005
    • 2077
    Have a 87 block/ and 88 head; when I warm up the engine the headers smoke....really smoke. Changed the valve cover gasket and cleaned with brake cleaner. Is there anything else
    I need to do. Where could the oil be coming from; or is it most likely years of oil leaking from the valve cover gasket?
    thanks,
    jm
  • digger
    • Nov 2005
    • 6207
    See if it burns off over time
    • 2002jm
      • Sep 2005
      • 2077
      yes, I was going to do that, but it sure is taking awhile:). If the headers, which are really just m20 exhaust manifolds get saturated, I assume it will take a long time to burn off.
      jm
      • TobyB
        • 5297
        Go drive it.
        They don't really get HOT at idle, so all that oil's just sitting there, smoking.
        You want it to burn, baby, burn!
        t
