M20 oil pressure sensor adapter
  • zaq123
    • Jul 2016
    • 1546
    Any good ideas to mount the oil pressure sensor and at the same time maintain stock cluster light operational as designed? Is there a way to go of the sensor alone for that (reading the actual pressure on the aux display and operating the dummy light at the same time)? Or I would need both, the sensor and the switch? Anyone knows how Alpina had the oil sensor integrated?
    I found the adapter from Bimmerheads (pictured). Any feedback? My concern with that setup: that oil will never be able to drain from that adapter, possibly gunking up both units over time.
    My Aux pressure display uses the sensor that is the same size as stock oil switch.
  • ForcedFirebird
    • Feb 2007
    • 8300
    We will have a new product soon, for this exact situation. Nice clean OEM setup. Just have to finish a couple more piston modifications and they will be in the lathe.
    john@m20guru.com
    Links:
    • zaq123
      • Jul 2016
      • 1546
      cool, any details on the installation location etc? 1/8npt?
      • Das Delfin
        • Sep 2014
        • 2293
        VDO makes a pressure sensor that will send both a variable signal to a gauge and an idiot light that will turn on at or below 8.5 psi, close to the stock 7 psi. I was searching their inventory on summit last week and cross checked the part numbers with VDO spec sheets and viola. No need for three sensors if your idea is to implement oil pressure and temp gauges along with keeping the original oil indicator light.
        https://www.vdo-gauges.com/sensors/p...x1-5-30-6.html
        • zaq123
          • Jul 2016
          • 1546
          unfortunately it's out of spec for my unit, it needs 5V powered sensor. What do you guys think about a sandwich plate mounted sensor (between the cooler adapter and the filter)?
          My sensor Click image for larger version
          • ForcedFirebird
            • Feb 2007
            • 8300
            Wow, the forum kept saying the post failed.
            Just above the oil pressure switch. I picked up a whole bunch of the big banjo bolt that goes through the oil filter adapter (11421711071). The plan is to center drill and tap them to 1/8" NPT. Not only convenient for a gauge, this will also give turbo guys a place to easily get a supply line. This way you don't need any 14mm adapters, extensions etc and can even keep the idiot light.
            john@m20guru.com
            Links:
            • whodwho
              • Jun 2008
              • 1547
              Works well there
              My M20 Frankenbuild(s)
              4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
              • digger
                • Nov 2005
                • 6162
                this is what i did, its the simplest way IMO
                • eLKuRLy
                  • Oct 2007
                  • 360
                  sandwich plate or on stock location?
                  • digger
                    • Nov 2005
                    • 6162
                    stock location, it needs an adapter that screws into the stock location as the VDO is too fat and the one i had was different thread iirc. i think i used one i got from BMP design when they still existed.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      Great ideas! Turbo peeps still need pressure feed, and race cars prefer mechanical gauges. Still relevant. ;)
                      So, the VDO still needs and extension/adapter? Never tried one, always used the dummy light locale and Autometer makes a nice 14mm pipe to 1/8" NPT for short money. Forget the part number, and may fix this post in the morning,e they are hanging on the office wall, but 2267 comes to mind.
                      john@m20guru.com
                      Links:
                      • zaq123
                        • Jul 2016
                        • 1546
                        decided to go with the sandwich plate between the filter and the oil cooler adapter. 14mm for the temp. sensor and 1/8npt for the oil pressure sensor. Another two spare ports. $18 isn't a bad price. Just have to tap for 14mm temp. sensor since this thing has all 4 ports as 1/8npt. Any concerns with this setup?
                        Click image for larger version  Name:	image1.png Views:	0 Size:	137.7 KB ID:	9917926
                        Click image for larger version  Name:	s-l1600.jpg Views:	0 Size:	43.6 KB ID:	9917927
                        • m3clutch
                          • Nov 2008
                          • 352
                          Any updates here on your efforts? Some good info around here, looking to add some oil info off my motor.
                          Flickr
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            Yes! Sorry I didn't update here, been selling them on fleabay.
                            $45 shipped with new washers/o-rings for forum members since no listing fees, just paypal to: Forced_Firebird at yahoo.com with a note "hollow bolt". :)
                            john@m20guru.com
                            Links:
                            • m3clutch
                              • Nov 2008
                              • 352
                              sweet, might need to cop, thanks for the reply! I got hasty and ordered a sandwich plate, but realized, I only really need to run oil temp at the filter housing.... unless, I don't suppose the chunky oil pressure sender would mount to the sandwich plate AND fit between the headers and block and still give an accurate reading (too close to header?)
                              Flickr
