Does regularly adding clay to the intake help seal the piston rings?
  • Kershaw
    • 11822
    I started messing with the rallycross ix that has sat for a few years. If it sits without starting for a few weeks it's now hard to start. Long cranking and some acceleration pedal pumping to get it going. Nice cloud of blue smoke on start up. I kept the filter changed regularly but I never took the boot off to clean the throttle body. And yes, that is is a finger swipe on the left side and yes, nothing even moved. Tacky!
    How bad do you guys think the bottom end is? Guesses on what the compression is?
    AWD > RWD
  • ForcedFirebird
    • Feb 2007
    • 8300
    I read on the internet that you can put sand in a running engine to port the cylinder head. Must be true!
    john@m20guru.com
    Links:
    • roguetoaster
      Biggus Tippus
      • 7830
      The bottom end is functional and still in the block, the compression is some. You'll be fine when you add boost.
      • TobyB
        • 5287
        Has to be red clay, though- the grey stuff is for the cooling system.
        t
        • Stanley Rockafella
          • Aug 2011
          • 4062
          Also great for cleaning off any carbon buildup caused by direct injection!
          • E30-325iS
            • Sep 2011
            • 191
            Sand will port the head, clay will extrude hone the manifold.
