What does this plug tell you?
  • LateFan
    • May 2013
    • 4415
    This is a bit different from things I've seen. One cylinder only, #6. Others had normal color and minor wear. My son says it wasn't gooey like it looks, it was hard, he scraped it off.
  • cheffy30
    • Sep 2016
    • 1159
    check this... https://ngksparkplugs.com/en/resources/read-spark-plug good luck. sent from hell using tapatalk
    '90 325i sedan daily driven
    '85 325e coupe also a daily
    • LateFan
      • May 2013
      • 4415
      Thanks. Yep, similar to the pics in most manuals. I'd say "deposits" is the closest. I wonder if if's oil, coolant? Looks like there's a bit of oil on the threads (?).
      • cheffy30
        • Sep 2016
        • 1159
        It's not uncommon for the head gasket to fail at the #6 end... could be internal if there is no apparent outside leaks. sent from hell using tapatalk
        • ForcedFirebird
          • Feb 2007
          • 8300
          Are you able to do a compression test and report back?
          john@m20guru.com
          Links:
          • LateFan
            • May 2013
            • 4415
            Yes, it's going to be here this weekend and that was on my list. We're adjusting valves etc.
            • Italian_Tuneup
              • Sep 2018
              • 128
              Looks like combusted oil residue. Bad rings will often foul the plug with oil and leave a tarry mess, but bad intake valve guides will continuously admit oil into the combustion process, but in small enough amounts it won't foul. But it will leave behind ashy stuff from the oil. Other identifiers, puff of smoke on startup, puff of smoke after long deceleration when you tip back into the throttle. Really bad guides and seals can show up on a vacuum gauge with a upsy-downsy type wobble of the needle... Best way I can describe it.
              1985 325e -> M60 swap project
              1983 GTV6
              1974 X1/9
              • LateFan
                • May 2013
                • 4415
                I know at some point in it's past someone overheated it and cracked the head. A "good used" head was tested and put on, but I'm nearly certain it wasn't rebuilt.
                • LateFan
                  • May 2013
                  • 4415
                  Compression test today :
                  Tested each one at least twice. Kept climbing through 20-25 pulses.
                  1 - 180 / 180
                  2 - 163 / 165 added teaspoon of oil: 190+
                  3 - 162 / 165 added teaspoon of oil: 187
                  4 - 180 / 180
                  5 - 175 / 176
                  6 - 180 / 180
                  So those are just at the edge of 10% apart.
                  Do these seem high for an eta?
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Not at all. The eta has higher compression and smaller duration cam, so they tend to test higher cranking compression. A fresh b25 stock will do 180-185, but those numbers drop to about 145-150 with a 272 camshaft.
                    162-180 isn't a deal-breaker as the car will run fine, but as you can see, you have a couple of sticky rings and be burning a bit of oil when the crankcase pressurizes.
                    EDIT: Odd that #6 compression tested good, and that's the one with deposits.
                    john@m20guru.com
                    Links:
                    • LateFan
                      • May 2013
                      • 4415
                      Maybe a guide at 6?
                      I should add, 195,000 miles on this.
                      • digger
                        • Nov 2005
                        • 6192
                        using any oil or fuel additives?
                        • LateFan
                          • May 2013
                          • 4415
                          None.
                          Regular Castrol GTX changes, twice a year. He's put 20,000 miles on this car in 7 years. We adjusted the valves this weekend as well, and they were all right on or within .001".
                          • cheffy30
                            • Sep 2016
                            • 1159
                            you clearly don't drive that little beast enough. she's jonesing for a tease .. drive her. she wants you. she likes you. don't be shy. sent from hell using tapatalk
                            • LateFan
                              • May 2013
                              • 4415
                              I often advocate the Italian tune-up.
