91 325i needs new engine head
  • Ant_146
    • Aug 2020
    • 4
    Hi everyone, I'm new and my knowledge is extremely limited. My vehicle stopped running about 3 weeks ago. Long story short, it started to shake and wouldnt start again after it was turned off. A friend opened up the engine head and there were broken pieces and cracks all over the place. Any ideas on what could've cause it? Will a head swap fix the problem and make the car run? Any help or advice will be greatly appreciated.
  • mike87
    • 300
    It looks like you have major damage to the parts of the head that hold down the intake rocker shaft.
    You definitely need a new head, not sure what caused that kind of damage though.
    • Tinkerer007
      • Mar 2013
      • 252
      Seems like the timing belt broke.
      • digger
        • Nov 2005
        • 6213
        Yeah my guess is Pistons and valves touched due to failed timing belt or similar
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          Definitely piston to valve, likely timing belt, maybe failed stamped gear.
          Originally posted by priapism
          Originally posted by shameson
