Need help dead m20
  • ADEN
    • 620
    Need help dead m20
    89 m20b20 lost power with oil burning opened it and found piston to bore too much clearance bad pistons and cylinder wall , searched for ages for b25 but couldn't find one but found only complete b25 block with no 885.
    I searched if i can mate it with my 731 head couldn't find an answer. Is this compnation doable?
  • ADEN
    • 620
    Any thoughts?
    • jeffnhiscars
      • Jun 2011
      • 6011
      The 731 is perfect for an eta block since it matches up w the flat pistons and preserves compression. If you put it on a 2.5 block I'm quite sure you will have valve to piston problems
      Alice the Time Capsule
      • ADEN
        • 620
        Thanks for your replay, That means no success with 2.5 upgrade
        • ADEN
          • 620
          What if i got a flat 2.5 pistons with the 2.5 block and 731 head on top of them.possible?
          • digger
            • Nov 2005
            • 6215
            You certainly could machine the m20b25 pistons so they are essentially flat ( whatever gives the appropriate stack height) but net result might lower the compression ratio not sure.
            • jeffnhiscars
              • Jun 2011
              • 6011
              I put a 731 w a 272 on our eta and it's a great engine. I'd look for a 2.7 block and not mess w a worn out 2.5 for which you don't have a head.
              • ADEN
                • 620
                Is that OK and safe??????
                If that's possible i would be very happy and appreciated
                • ADEN
                  • 620
                  I am working here with very limited options where i live. I am trying to keep the E30 alive and in good shape
                  That WORN 2.5 block searched for it for almost 2 years i can order parts online (rings, bearings, gaskets...etc)but shipping a block or a head cost a fortune.
                  My E30 is parked sadly waiting for a good upgraded motor after the b20 encounted a piston slap in the morning and lost alot of power.
                  • digger
                    • Nov 2005
                    • 6215
                    Yes, it’ll be fine
                    • ADEN
                      • 620
                      Thanks digger
