E30 Stroker 2.7L CA Smog Questions
  • Rockonp04
    • Sep 2020
    • 75
    #31
    Originally posted by digger
    i highly recommend to stick with their Mahle MS ones in that case, the other 2618 alloys wear poorly, rattle when cold etc due to the low silicon content and associated high expansion. They are actually inferior to stock cast pistons in many ways, most forged pistons are. That's why Andrew (formerly IE) worked with Mahle MS to develop them for the street. if you want something for a non street application or very low mileage or very high boost then 2618 will work but don't fall into the trap that almost everyone else does thinking forged pistons are magic and need no engineering.
    I think I understand your point now. You are referencing these pistons.https://www.iemotorsport.com/product...-ie-mahle-m20/
    I would be making a 2.9L and not a 2.8 using these pistons. It seems I could use pretty much all of my M20B25 block, rods, and head with this, just only have to buy a M52 crank, right? I think I understand your point about the wear of the piston now.
    Any advice on this build? Is it that simple to just throw these pistons and the M52 crank in?
    • digger
      • Nov 2005
      • 6190
      #32
      You need the m52 crank and a sleeve / new crank bolt (from24v engine) and thinner washer. Ie probably can sell you or metric mechanic and other vendors
      • Rockonp04
        • Sep 2020
        • 75
        #33
        After a long think, I decided just to go with the custom forged pistons from Ireland Engineering. Also, when calculating the budget for a 2.9L engine build it was significantly more than the 2.7L build. I respect your opinion on the Mahle pistons but after talking to Jeff I don't see a huge advantage to spending the extra money and also I would like to pass smog in California. Thank you for showing me all the alternatives before jumping into this build. As they say, knowledge is power.
        • ForcedFirebird
          • Feb 2007
          • 8300
          #34
          You do realize Jeff carries a very specific piston for you expectations, that a "local" member "skifree" did all the research on, and got Mhale to produce a correct piston for you intended use.
          Ultimately, it is YOUR engine, this is just a stupid online forum for a bunch or e30 fanatics to hang out and shoot poo.......BUTTTT!!!
          Not for nothing, the guys who are having good results, "should" be the guys you are listening to. :p
          john@m20guru.com
          Links:
          • Rockonp04
            • Sep 2020
            • 75
            #35
            Jeff is who I have been talking to and he has the exact piston which will work for this stroker kit. I could go with the Ireland Engineering 2.9 Mahle piston kit but I am not pushing my luck for smog and blowing my budget. The custom forged piston Jeff supplies will work perfectly for my application. That's what I am going to do and I am sticking to it.
            This is the piston set I am going to use.
            • ForcedFirebird
              • Feb 2007
              • 8300
              #36
              Yeah, budget-wise the Mhale are more expensive, but usually cost vs quality is often reflected in price.
              john@m20guru.com
              Links:
              • Rockonp04
                • Sep 2020
                • 75
                #37
                An update on the build. I purchased some 17lb green top injectors from Injector Planet. https://www.injectorplanet.com/produ...mw-13641730060. These, for now, work with my current stock setup and I think will be adequate with the 2.8 stroker.
                I am still going to do the forged pistons from Ireland Engineering but had some questions about cams. I really want to pass smog no problem and don't want to have to register my car in Arizona. I've head videos of the 272 cam and it seems lopey and heard about the overlap issues. I am leaning toward a stock cam at the moment just to avoid the hassle. I am not looking for crazy horsepower just something better than stock.
                What is everyone's thoughts with a stroker, with a stock cam, 17lbs injectors, and an upgraded chip?
                • Rockonp04
                  • Sep 2020
                  • 75
                  #38
                  • medgingt
                    • May 2021
                    • 11
                    #39
                    I'd highly recommend going with a piston that uses the OE dome as others have suggested. If you don't want to go with the 2.9, Top End have JEs that fit the bill as Digger pointed out. Especially since you are worried about Smog...the correct combustion chamber will be your friend.
                    • Rockonp04
                      • Sep 2020
                      • 75
                      #40
                      I have had a discussion with Bimmerheads about passing smog with certain pistons and cams. They have a set of pistons with a compression ratio of 9:1 with the 274 cam which they claim will pass smog. I think this will be my current path. No idea what piston shape they have.
                      • mkcman17
                        • Jul 2010
                        • 8240
                        #41
                        I built my 2.7i (88 bottom in 89 body) with a regrind cam, 17# injectors, and a knock off chip and my car has passed bi-annual smog the last three times on its own in socal
                        1989 LN106 Hilux / 3.0TD SFA
                        1974 2002tii / stock
                        2002 IS300 / 5spd LSD
                        • Rockonp04
                          • Sep 2020
                          • 75
                          #42
                          What cam are you using?
                          • mkcman17
                            • Jul 2010
                            • 8240
                            #43
                            Regrind ~274. have been running this setup since 2012
