Engine acting up after head gasket/timing belt ect.
  • E30andy
    • Aug 2016
    • 504
    Originally posted by Nader393
    Make sure the distributor rotor is indexed correctly on the cam timing pulley. Even if you think it is, go back and take it apart and re-check. I had this problem myself.
    This 100%! Same thing happened to me, car wouldnt start after TB change. Online instructions did not mention this very important step. Went back and put the rotor on in the correct orientation and she started right up.
    89 325ix coupe Diamondschwartz
    1994 Mazda Miata
    • digger
      • Nov 2005
      • 6194
      it only goes on 1 way doesnt it? the cam gear is dowelled, the rotor adaptor is keyed and rotor only fits 1 way due to bolt pattern?
      • E30andy
        • Aug 2016
        • 504
        Nope, I put it on the wrong way. It is keyed, but still possible to put it on wrong if you dont know its keyed. So, if you just put it on without paying attention to keying it properly, its likely its on wrong and thats your problem.
        1994 Mazda Miata
        • romeo294
          • Aug 2015
          • 77
          Aden and Nader, thanks for ideas. I’ll check.
          • romeo294
            • Aug 2015
            • 77
            If it’s not indexed properly do have to take the whole cam sprocket off, or can I remove that index piece so it’s correct?
            • Nader393
              • Dec 2015
              • 408
              No, just remove the rotor. If the cam pulley is not indexed and seated correctly, then the belt would probably not fit.
              '91 325i
              • digger
                • Nov 2005
                • 6194
                just checked on spare head It is massively on the piss when it’s oriented incorrectly. I can’t see how anyone would not notice that. You’d bend something if you torqued it down like that.
                • romeo294
                  • Aug 2015
                  • 77
                  Welp, that was it.... I didn't have it indexed correctly. I'm the moron. I just wish I got your answer before I sent it to the mechanic. Could have saved be a little bit of money. Oh well, it's working now. Thanks for the answer.
                  • digger
                    • Nov 2005
                    • 6194
                    cant argue with that
                    • romeo294
                      • Aug 2015
                      • 77
                      ^ha. Chalking it up to learning experience. Funny part is my father was like “check the distributor again” and I kept telling him rotor only goes on one way. Should have looked deeper. Oh well. I appreciate this forum and the people here who’ve helped.
                      • tomstin
                        • Mar 2015
                        • 571
                        It's always hard to double check your own work, you tend to assume. When I was writing papers in college one of the professors told me to re-read the papers from the bottom up, forces you to read the individual sentence. Same sort of thing trouble shooting, inspect one thing at a time as an individual part. Hell, I think we've all skimmed over something trouble shooting a problem! Glad you got it sorted!
                        2004 525i Manual - 1985 325E Coupe Manual
                        • romeo294
                          • Aug 2015
                          • 77
                          Thanks, just pissed that I missed something so small. Again, learning experience.
