Cometic mls
  • tiger_e30
    • Dec 2016
    • 219
    Cometic mls
    Brought a cometic mls and it won't fit on the m20 block. Doesn't have enough clearance for one of the the 2 12.50 mm dowel head locator pins. Looking at the gasket I can tell one hole is smaller. Anyone ever run across this before?
  • digger
    • Nov 2005
    • 6119
    I've had them send a gasket with the bottom layer having an incorrect bore size with other layers being ok, sent it back and they sent a replacement. Can you not dremel it and deburr, clean thoroughly etc??
    kinda weird this could happen as all m20 gaskets should be the same in this regard and on file.
    • tiger_e30
      • Dec 2016
      • 219
      Hmm i can check if it's just one layer off. I was thinking about filling the split pin a little to reduce od
      Do you know what the od of both holes on the gasket should be?
      • tiger_e30
        • Dec 2016
        • 219
        I make the dowels ar 12.50 and one gasket hole 13.75 and the other 12.40
        • digger
          • Nov 2005
          • 6119
          for reference i will check a couple of mine that i have lying around and get back to you
          • tiger_e30
            • Dec 2016
            • 219
            Much appreciated
            • digger
              • Nov 2005
              • 6119
              all holes are between 12.4 to 12.5mm one end of gasket fits nicely the other is very tight could fit with some persuation i will just dremel it with a cylindercal stone if i still have issue with a new dowel. Same on two seperate gaskets oddly enough trying the tight hole on the other dowel doesnt fit either so the old dowel might be the issue
              • tiger_e30
                • Dec 2016
                • 219
                Weird that one of my holes is so oversized then. I tried filing the dowel split but the block won't compress it beyond 12.50
                • digger
                  • Nov 2005
                  • 6119
                  dremel out the bore with a stone, just cover and protect the gasket so grit and metal doesnt get between layers etc
                  • JehTehsus
                    • Dec 2019
                    • 269
                    Thanks a ton for posting this thread when you did by the way - I would have taken a lot longer to figure out I missed my dowel pins during install lol.
                    I just ordered a replacement MLS from IE (and have dowels arriving separately). I will let you know if the dowel holes are the right size.
                    • tiger_e30
                      • Dec 2016
                      • 219
                      Will do. Thank you
                      • tiger_e30
                        • Dec 2016
                        • 219
                        Oh dang glad you caught that. Would have really sucked to do all that work then have the head move! I'm glad it helped you out
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          It's because they copied the VR gasket. The VR is the same way, just easier to get over the dowel when it's composite. They also copied the oval hole for the oil supply and head bolt, rather than having them separate like the Goetze/OEM gasket is.
                          Sorry, been busy at works and not singing in here much, but I haven't had any issues in the last 1.5 decades by opening the hole a little as Digger mentioned.
                          john@m20guru.com
                          Links:
                          • tiger_e30
                            • Dec 2016
                            • 219
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              john@m20guru.com
                              Links:
