I need help quickly, while my car is briefly in the shop
  • fakeplstctrees
    • Jun 2013
    • 92
    Hello my fellow elders, I need your accumulated wisdom, as soon as possible. I recently did a rejuvenation on my 89 325i. But one issue has not been seen to. The cast majority of the times I start my car up, it immediately starts. But it sporadically cranks for several seconds before starting. Sometimes I have to try starting it a second time before it actually starts. Have any of you dearly with this issue before, and if so, what was the remedy? Thanks so much! Sent from my SM-G973U using Tapatalk
  • McGyver
    • 4636
    Its likely that it takes a while to build up fuel pressure, which is why it takes a while to crank or needs a second attempt. The cause is the check valve in the fuel line is slowly leaking, letting the pressure drop. If it's what I'm guessing, it's not something I would worry about.
    • fakeplstctrees
      • Jun 2013
      • 92
      So maybe a fuel pressure regulator? Sent from my SM-G973U using Tapatalk
      • Gregs///M
        • Mar 2012
        • 2459
        Id consider vacuum leak unless your motor has been completely rebuilt and all rubber, gaskets, and hoses have been replaced. Also, I would perform the complete DME electrical tests in the manual to verify all your electrical sensors are operating within range.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • fakeplstctrees
          • Jun 2013
          • 92
          I've reached out to the rejuvenation team at Enthusiast Auto Group, I figured they've probably seen it all. And my baby is up to their standards BTW. But they narrowed it down to 3 potential problems, with 1 being the likely culprit. 1) Crank Position Sensor. 2) Fuel Pressure Regulator. 3) Engine Temperature Sensor. All are easy repairs. Thanks for your help guys! Sent from my SM-G973U using Tapatalk
          • digger
            • Nov 2005
            • 6213
            is it on cold start, warm start, hot start or all?
            • fakeplstctrees
              • Jun 2013
              • 92
              All, and totally sporadic. It's most likely the Crank Position Sensor. It's actually the original factory sensor, it's probably gradually failing, so I'm replacing it. Sent from my SM-G973U using Tapatalk
              • e30austin
                • 15382
                fuel pump
                blue coolant temp sensor
                never seen a crank sensor do what you're describing; i'm not saying it isn't possible, but they (generally speaking, of course) either work or they don't. not a bad idea to replace it with a genuine unit from the dealer, though.
                • fakeplstctrees
                  • Jun 2013
                  • 92
                  Originally posted by e30austin
                  fuel pressure regulator fuel pump blue coolant temp sensor never seen a crank sensor do what you're describing; i'm not saying it isn't possible, but they (generally speaking, of course) either work or they don't. not a bad idea to replace it with a genuine unit from the dealer, though.
                  https://www.yourmechanic.com/article...osition-sensor Checkout symptom 1, it describes what I'm experiencing. And it's such a cheap part and easy install, it's definitely worth a shot. Thank you for the feedback, definitely appreciated! Sent from my SM-G973U using Tapatalk
                  • digger
                    • Nov 2005
                    • 6213
                    fuel pump
                    i'd add injectors to the list
                    • e30austin
                      • 15382
                      likely one of the most overlooked items on old vehicle maintenance. yes, clogged/dirty injectors for sure.
                      • fakeplstctrees
                        • Jun 2013
                        • 92
                        The injectors spray a mist, worthy of Sigourney Weaver and her Gorilla's. Sent from my SM-G973U using Tapatalk
