m30 firewall modification
  • flawdaboi407
    • Mar 2008
    • 324
    Where and how much must I bang in the firewall for the e30.de mounts in pos 2? I did search a lil but didnt find anything. Thanks.
    84' 318i m30b35 swapped!
  • E30SPDFRK
    • 5716
    b34 or b35?
    There really isn't a specified amount, you just kind of go in there and start beating away.
    Byron
    Leichtbau
    • flawdaboi407
      • Mar 2008
      • 324
      m30b35 from a e32 735i
      • yert315
        • 2734
        you shouldn't have to bang on the firewall with a b35. especially in pos 2.
        I am using Funkmasta's mounts and the b35 fits in there snugly with the insulation still in.
        • flawdaboi407
          • Mar 2008
          • 324
          I thought I read somewhere you have to bang the firewall to scoot it all the way back for the furthest position.... to clear the head....?
          • yert315
            • 2734
            The b34 heads have a fitting on the back of the head that the b35 does not. This is why some people massage the firewall for clearance.
            Here's a picture from realoem:
            #11 is what hits the firewall. An m30b35 cylinder head does not have this.
            You should not have to touch the firewall with a b35
            • LKTe30
              • Dec 2004
              • 151
              I have a m30b35 with e30.de mounts in position 2 and didn't have to bang the firewall, it was close and with no insulation. But if I wanted to get into position 3 then I would have had to beat it a good amount.
              mike@lookoutdrift.com
              • drift
                • 566
                So, you can switch to position 3 ?
                (using your existing " position 2 " e30.de mounts ) ?
                Do they have 2 different mounting holes ?
                http://www.kingofeurope.net/2010/
                • flawdaboi407
                  • Mar 2008
                  • 324
                  I mean pos 3 mybad.
                  • drift
                    • 566
                    ^ So, did u get your B35 installed on Position 3 ?
                    • flawdaboi407
                      • Mar 2008
                      • 324
                      so where do i start to hammer
                      • yert315
                        • 2734
                        Have you tried fitting it in there yet? I ended up cutting some of the sound insulation on the firewall, and had about a couple cm of clearance.
                        • Good & Tight
                          • Apr 2004
                          • 2057
                          Everywhere, just go to town on it.
                          j/k :)
                          You should position the engine in and mark on the firewall were it needs some modification.
                          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                          ____________________________
                          E-mail Panayiotisx2@gmail.com
                          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                          • flawdaboi407
                            • Mar 2008
                            • 324
                            fuck that. too much work.... im just gonna beat it everywhere :)
                            ps. see that bronze brake line thingy under the brake fluid resovior? What is that called? I need to replace it.
                            • drift
                              • 566
                              ^ The one on the ground, It's Clutch Slave Cylinder
