And another M30 swap begins
  • E30 Beast
    • Jan 2010
    • 182
    #151
    thanks "Sacse30" with the helpful information and thanks to "Jean" also, im trying to learn as i go but this electrical has got me all confused and that is the harness I am working with, one off an e32 with the 25 pin plug
    • E30 Beast
      • Jan 2010
      • 182
      #152
      not getting any power to the injectors, and reverse polarity on main relay, nd fuel pump relay any thoughts?
      • E30 Beast
        • Jan 2010
        • 182
        #153
        anyone?
        • Garageaholic
          Freestyle Fabricator
          • Dec 2005
          • 5204
          #154
          Did you get the Rev B of my Writeup? The electrical section was beefed up substantially.
          Also, did you get the email I sent you. I had some corrections to your pin assignments.
          Let me know if it helped. I didn't get any feedback from you.
          Thanks,
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          Instagram.com/garageaholic
          Youtube.com/garageaholic
          • Garageaholic
            • Dec 2005
            • 5204
            #155
            Not to double post, but now I see what E32 plug you went with; The 25 pin C101.
            This makes it much more difficult, but if you tell us which year 735i you got your E32 harness from, we can help match it up for you pin for pin.
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            • E30 Beast
              • Jan 2010
              • 182
              #156
              Thanks Frank i believe the harness is from an 88 or 89 735 il, Is it possible that my motor wont start because i didn't do the TDC right?
              • Jean
                • 18228
                #157
                88/89 had a 20 pin, your must might be from 90/91.... Did you look at my thread with 25pin c101 pinouts? They are all there, you just need to match them with your 20pin.
                • E30 Beast
                  • Jan 2010
                  • 182
                  #158
                  I had looked at your thread and tried to match the pins but it still wasn't getting any power to the main relays nd the fuel pump relay.
                  • Jean
                    • 18228
                    #159
                    Post here what you have connected and where.
                    You have harness ground and power connected right?
                    • E30 Beast
                      • Jan 2010
                      • 182
                      #160
                      hey guys had a question can i use any other radiators because i really cant find any out here in cali in good condition so i purchased a new one nd turns out the new one was bad could i use like an e34 or e36 radiator?
                      • Jean
                        • 18228
                        #161
                        no, unless you modify your firewall and push the engine further back (and use custom mounts and possibly driveshaft)
                        • E30 Beast
                          • Jan 2010
                          • 182
                          #162
                          well i did already modify my firewall to position the motor as far as it could go (Good nd Tight mounts) which gives me about three - four finger clearance from the motor nd the frame would that help
                          • Jean
                            • 18228
                            #163
                            Only one way to to find out, test fit one.
