M62 vs S54
^ not legal in SMMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
The OP states that the Ellis Juan is not an option. (edit: waay late on this revelation)
I'd probably want to go with the S54 due to more area under the curve (and 8000rpm) but the M62 might be a bit quicker autocrossing due to the likely better weight distribution and the power delivery characteristics.
Regarding torque, well yeah the M62's obviously going to put out more brute force, but if you take into account the gearing advantage that the S54 makes possible (2000 more rpm to play with) it is not so bad. The M62 is going to be a little quicker than its peak hp number suggests, but the s54 will still obviously be the quicker motor when you get some room to stretch its legs.paint sucksComment
Yes, it's not a big deal really, and makes most sense since it's driven on the road to the events etc. Plus, why would I want a more expensive motor with almost the same power as more available m62/s54?? To me that doesn't make any sense. I don't care about the bling.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
i'm trying to decide between euro s50b32 and s54. cost is about the same. would like to graduate from s50/s52 swaps to the next (faster) level. by the way I have 3 s5x e30's for sale lolOriginally posted by bluntcan you get me a deal on cases of their (fiji) bottled water? i wash my 02 in that shitComment
S50B32 isn't even in the same league as the S54. Don't even mention it in the same thread.
RTFM:http://www.r3vlimited.com/board/showthread.php?t=56950Comment
v12 are a waste of effort imho.... and boost is not in option in CA that's why i narrowed it down to two choices :)
Couple benefits I see to s54 over m60/2 - no need to lower front subframe, no need to relocate mc/booster hardware to the very front of the car. Longer rpm range, cheaper tranny, ITB, newer, lower mileage choices, mechanically almost a bolt in swap.
I hate to say it but on paper s54 looks better.... no?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
