The m30 with Getrag 240 thread
This is a sticky topic.
  • marshallnoise
    • Sep 2013
    • 3148
    Originally posted by the imitator
    should overnight me a burrito in a small lunch box with ice packs in there.
    Hotter the better though!
    Si vis pacem, para bellum.
    New Hawtness: 1995 540i/6 Claptrap
    Defunct too: Cirrusblau m30 Project
    Defunct (sold): Alta Vista
    79 Bronco SHTF Build
    • rob0r
      • Aug 2013
      • 4
      I've done this twice now.
      E30 320i Touring:
      M10 box
      M10 flywheel
      M10 paddle clutch
      E30 320i prop
      E30 320i gear linkage
      E30 320i saloon
      M10 box
      S14 M3 flywheel
      M20 Paddle clutch
      E30 320i prop
      The S14 flywheel has the correct starter ring for the M30 and allows fitment of a bigger S14/M20 clutch, which still all fits under the M10 box. Just using the M10 fly and uprated paddle clutch I had some slip in the higher revs which is why I've gone for S14 setup this time.
      • marshallnoise
        • Sep 2013
        • 3148
        E30 320i Touring:
        M10 box
        M10 flywheel
        M10 paddle clutch
        E30 320i prop
        E30 320i saloon
        M10 box
        S14 M3 flywheel
        M20 Paddle clutch
        E30 320i prop
        That is some great information here. I was looking into how to use the m20 pressure plate and clutch and the s14 flywheel was the only way to do it reasonably. The other option was to cut the ring gear off the m20 flywheel and put one on from an m10/m30.
        Thanks for the great post man!
        Sent from my SPH-L710 using Tapatalk
        • rob0r
          • Aug 2013
          • 4
          No problem. I only got the engine running properly and car driving with the 2nd setup last night and I can confirm that all seems good. I used the release bearing from the M20 clutch and the pedal seems OK.
          Top left S14 M3, top right E28 M535i, bottom M20
          As above, note the teeth pitch difference
          S14 flywheel fitted up with the M20 paddle clutch
          • marshallnoise
            • Sep 2013
            • 3148
            Did some more research, just out of boredom really, and found a great thread on bimmerforums.
            Basically the 228mm m10 flywheel with m20 clutch and pressure plate works just fine. There is some debate about throwout bearing, but someone also posted up a working combo. These guys are talking like support for 250 horsepower and 275lb of torque. Should be good enough for an NA m30.
            Hey fellas, I'm wondering if any 2002 guys have ever run the m20 pressure plate on an m10 228 flywheel? I'm just wondering if there is any difference (besides the m20 PP being cheaper)?
            Metric Mechanic says that when you run a 228mm clutch with the Getrag 245 or G240 transmission (rather than the 4 speed), you have to run the 25mm throwout bearing, but they don't list the BMW part number. Everything else I've read says to use the e21 323i "525" TO bearing with this combo. When comparing it to the stock 320i TO bearing I found that the 320i bearing measures 25mm from clutch fork ears to bearing surface, while the 323i bearing measures 30mm.
            e21 320i TO Bearing:
            21 51 2 226 729 - 25mm
            e21 323i TO Bearing:
            21 51 1 204 525 - 30mm
            Also interesting is that the 228mm flywheel (e30 m3 and I believe 2002 as well) is ~5mm taller than the 215mm flywheel, while the stack height of the 2002 228mm pressure plate is about 5mm shorter than that of the 215mm PP.
            320i 215mm pressure plate height:
            53.5mm (PP) + 25.8mm (flywheel) = 79.3mm total
            2002 228mm pressure plate height:
            47.7mm (PP) + 30.9mm (flywheel) = 78.6mm total
            Here's pics of my parts (click the link), the 215mm setup I'm getting rid of and the 228mm setup I'm swapping to on the right (once I get a shipping damage issue resolve):
            So, why on earth do you need to run the taller "525" throw out bearing when the overall stack height of the flywheel and pressure plate is almost identical? I measured almost a 10mm gap between the TO bearing and the PP fingers with the clutch fork fully depressed, which means I'm wasting that amount of slave cylinder travel with the short 320i TO bearing (on my "stock" 215mm setup).
            Also, TEP told me that I was getting the Sachs sport pressure plate (Sachs # 88 3082 618) and that they would upgrade it even further for higher clamping pressure. They actually sent the stock 2002 pressure plate (PN 21 21 1 251 248) which costs $100 compared to the m20 pressure plate (PN 21 21 1 223 026) which costs $65. I'm not even sure they upgraded it but that is another question I will ask TEP. My question to the forum is, they look identical, what is the difference? Is the m20 pressure plate shorter? Does anyone know if one has a different clamping pressure?
            Also, here is a setup that is verified to work from the same thread:
            Not sure of all the variations, but my combo, as advised/provided by Ireland Engineering, for my 320 overdrive 5-speed converted, performance-modded 2002 is:
            BMW (Sachs) E30 M3 228mm Pressure plate -- superb clamping pressure, same as Sachs HD, with 'normal' clutch pedal feel.
            BMW (Sachs) 228mm 2002tii clutch disk -- with the greater clamping pressure from the M3 PP holds solid up to 250whp, even though it has less copper than the Sachs HD clutch.
            BMW 323i Throwout bearing -- to pair with 228 clutch. [if 215 clutch, then 320i TO bearing is used.]
            Mated to a JB Racing lightweight aluminum flywheel.
            A simply awesome combo...
            For reference, m10 228mm flywheels are found on the following cars. And they are single mass flywheels.
            • 1968 - 73 2002 w/ M10 2.0L - 4 cyl.
            • 1972 - 74 2002tii w/ M10 2.0L - 4 cyl.
            • lukeADE335i
              • Apr 2013
              • 1388
              I ran the e30 M3 clutch behind my setup with an M20 flywheel when I first did my swap. The M3 clutch and pressure plate were great behind the M30, no slip & good bite and pedal. Of course, the M20 ring gear died within a month, so I took that setup out and went with an uprated M10 215mm flywheel with uprated clutch as I couldn't get an affordable M10 228mm flywheel.
              If you can get hold of the 228mm flywheel, the S14 clutch & pressure plate is a good option.
              My e30: OEM+ with M30B35
              • marshallnoise
                • Sep 2013
                • 3148
                Ahhh, that was your story I read about. I have been on bmw2002faq trying to source that flywheel as I think that is the most cost effective solution for me.
                I really like the idea of the smaller bellhousing of the 240 for fitment purposes.
                • lukeADE335i
                  • Apr 2013
                  • 1388
                  yeah - my efforts at using the 228mm clutch are well documented over on EUROCCA (which is probably where you saw the thread).
                  The 240 is good for removal and fitment - if you read my tread over there, then you would have seen that I removed the gearbox & swapped the flywheels & clutches with the engine still in the car, which is seemingly problematic with the G260. Some leave the top two bolts out to aid in gearbox removal, but this certainly isn't necessary with the G240.
                  • glnr13
                    • 1334
                    e34 clutch/flywheel/pressure plate mated up to 240 sounds plausible along with the e34 throwout bearing?
                    all items coming from 535i.
                    it's a 240mm though... anyone with experience using this setup?
                    edit:just reading your thread on eurocca. looks like someone is running e28 setup in his e34 so i know that combo works just hoping it slaps into the 240
                    • marshallnoise
                      • Sep 2013
                      • 3148
                      Originally posted by glnr13
                      e34 clutch/flywheel/pressure plate mated up to 240 sounds plausible using the e34 throwout bearing?
                      it's also a 228mm... anyone with experience using this setup?
                      I did a quick lookup and show the e34 m30 flywheel as being 240mm. I don't think it will work.
                      • glnr13
                        • 1334
                        yeah, i was looking it up on realoem too. 12mm too big
                        • navytapaul
                          • 615
                          Get an e28 flywheel if you can, they're also lighter than the e34 setup.
                          Sent from my SAMSUNG-SGH-I727 using Tapatalk
                          • lukeADE335i
                            • Apr 2013
                            • 1388
                            The 240mm clutch and pressure plate will not clear the Getrag 240 bell housing.
                            • marshallnoise
                              • Sep 2013
                              • 3148
                              This is a totally blind question because I don't have my 240 out to see or a spare 240mm flywheel for that matter, but is clearancing the Getrag 240 bell out of the question for fitting a 240mm clutch setup?
                              /ignorant question
                              • lukeADE335i
                                • Apr 2013
                                • 1388
                                The bell housing isn't deep enough to clear the 240mm pressure plate.
                                I have heard that the bell housing can be machined to clear it, but have not seen such a set up anywhere, either in person, or pics.
