Want to do an M30 swap
  • JoeMadoo
    • 936
    #106
    Ok a few more questions for the pro's...
    The new harness (89 325i) has alot more pins than the 86 eta fuse box connector. Does this mean that i need a 325i fusebox?
    Ok next.
    What do these 3 wires do on both my old and new harness? They are different colors, so i dunno if they match or ever go to the same thing.
    Lastly, wtf is this. Only on my 325es harness.
    THanks to anyone!
    '86 E30
    '05 E53 X5
    '72 Firebird
    '10 Prius
    '03 Tundra
    • euroshark
      • Apr 2006
      • 3491
      #107
      First, you may not have all of the functions of the i harness in the e car, so if any wires dont match, just don't use them! Haha, thats the simple solution...
      Second, on the e harness I think they go to the gauge cluster. Not sure on the i harness....
      Third, that is the idle control module. You won't be using that with the i harness, only etas and early M30 cars with motronic used those, the later electronics (your i harness) have the idle control valve run right off the ecu.
      • Mr Deagle
        • 1121
        #108
        Ok next.
        THanks to anyone!
        PM Sent
        • JoeMadoo
          • 936
          #109
          THanks for the replys. Im concerend though cuz the I harness has more pins than the eta fuse box puts out...
          '86 E30
          '05 E53 X5
          '72 Firebird
          '10 Prius
          '03 Tundra
          • euroshark
            • Apr 2006
            • 3491
            #110
            Do you have the pinouts? Most likely they are for sensors that you will not need, or you will need to rewire elsewhere. Oil level sensor for example... If you have pinouts, I will help you determine which ones in the harness are necessary and which ones are not.
            In my experience, you will have every necessary function and a few that are connected to warning lights / diagnostic / check panel. There are only like 6 or 7 wires that HAVE to be connected for the car to run... At least that was the case in my swap and I have an '84 325e chassis.
            • Axxe
              • Aug 2004
              • 3355
              #111
              '87 325i harness would work better, wouldn't it?
              Keep it slideways!!
              • JoeMadoo
                • 936
                #112
                Is an M3 driveshaft a direct fit?
                '86 E30
                '05 E53 X5
                '72 Firebird
                '10 Prius
                '03 Tundra
                • Funkmasta
                  • May 2004
                  • 7185
                  #113
                  THanks to anyone!
                  holy thumbnail batman!
                  jk
                  starting my swap next week ;)
                  Joe Funk -- Portland Oregon
                  That Guy.
                  03 X5. 3 liter obviously.
                  • george graves
                    • 20003
                    #114
                    Noooooooooooooooooooooooooooooooooooooo.....It needs to be shortened.
                    Originally posted by Matt-B
                    • Garageaholic
                      Freestyle Fabricator
                      • Dec 2005
                      • 5204
                      #115
                      It also depends on which motorposition you decide to go with and which mounts you use/make/buy.
                      Recent Rebranding!!
                      E30 SM62/S62
                      E30 M60 V8
                      E30 M30 Big 6!
                      Instagram.com/garageaholic
                      Youtube.com/garageaholic
                      • JoeMadoo
                        • 936
                        #116
                        I see, i thought i read somewhere it was a direct fit. I'm going to use the e30.de mounts with either pos 2 or 3, or 2.5. Which driveshaft is a direct fit? It's so hard to find a straight answer...
                        So i have a full E30 M3 driveshaft, 89 325i driveshaft, and access to an e28 535i driveshaft, and an E32 735i driveshaft...
                        '86 E30
                        '05 E53 X5
                        '72 Firebird
                        '10 Prius
                        '03 Tundra
                        • Axxe
                          • Aug 2004
                          • 3355
                          #117
                          Anyone know what the hell is going on with mye28.com? I registered months ago and am still not confirmed/added.
                          Keep it slideways!!
                          • JoeMadoo
                            • 936
                            #118
                            maybe cuz you have an e30...
                            How did you guys hook up the cooling and the heater core with the M30? and And I'm guessing the send line is the one that comes from the filter right... into the FPR?
                            And does the M20 wiring harness have a sensor for the EGR valve like the M30 does?
                            '86 E30
                            '05 E53 X5
                            '72 Firebird
                            '10 Prius
                            '03 Tundra
                            • MrK
                              • Jan 2006
                              • 709
                              #119
                              I'm also stumped on the heater core connections... a diagram of sorts would be golden about now.
                              This is your M20 on steroids:
                              • euroshark
                                • Apr 2006
                                • 3491
                                #120
                                I used the stock M30 (6 series) hoses to the heater core and they fit perfectly.
