M30 E30 official roll call thread
This is a sticky topic.
  • SpeicherBimmer
    • Apr 2012
    • 365
    #106
    So the car is finally just about as done as it's going to be for a while...
    Located in Speicher, Germany
    Fully rebuilt Euro M30B34 ( 218hp non-cat)
    Motronic 1.3
    4.10 diff
    Custom equal length headers
    Full 2.25" SS exhaust
    I still have to get my fan wired up and the correct thermostat installed to get her running just right. I hope to get a cam, injectors and chip by the end of the year before I move back to Atlanta. We are supposed to be having a car show in August with dyno; hopefully I will be able to see what she's putting out. I can tell you that it sure does move with that 4.10 diff...
    sigpic'87 335i
    • walinsky
      • 16
      #107
      Greetings from Holland
      I think I belong here now too...
      Started out with a '84 316 (carb) automatic...
      Modlist including - but not limited to:
      M30B35
      Getrag 265 (dogleg) sports transmission
      Powerflex black polyurethane bushings all around
      21 and 14.5 mm stabilizer bars with new drop links
      New control arms with M3 eccentric bushings
      Z3 rebuilt steering rack (2.7 turns lock-to-lock)
      51mm front legs
      ventilated front disk brake conversion(rebuilt calipers - ATE Powerdisc)
      rear disk brake conversion (6-cyl trailing arms; rebuilt calipers)
      braided ss brake lines
      60/60mm lowering with adjustable (shortened) koni shocks
      rebuilt 2.93 lsd (40/40)
      Fitted new 255lph TRE fuel pump
      All new fuel lines back and forth
      Fitted round C101 to chassis loom (inc. rpm and econometer)
      Fitted 3 pedal box
      Battery in trunk retrofit (Odyssey PC680 dry cell battery)
      M3 tranny crossmember
      300mm.de engine mounts pos.3 / 75mm x 50mm poly bushes
      Shortened driveshaft to 1395 mm (combined e30 back and e34 front half)
      New water pump/thermostat/hoses/sensors/distributor/plugs and wires
      E28 Aircon Radiator
      New clutch master and slave cylinder
      M30 engine loom
      16" Spal fan triggered by 2 temp switches on rad; OEM low speed resistor; 2 relays in fusebox
      BTB ss exhaust
      Need to clean things up a bit now.
      Will send in pics when I have fitted the Mtech 1 kit and the staggered set of 16" Alpinas.
      Some random images:
      • dishwab
        • Mar 2012
        • 681
        #108
        Originally posted by walinsky
        What headers are these?
        • walinsky
          • 16
          #109
          BTB
          Racecar specialises in supplying the automotive industry with world class digital solutions including web, software, app and graphical design
          I was lucky to get my hands on a used one.
          They are true pieces of art.
          The invoice from 2009 stated £750 ex vat for the headers. (indeed - that's not a dollar sign)
          • dishwab
            • Mar 2012
            • 681
            #110
            That's what I was afraid of... Way out of my budget for this swap but they look great!
            • lukeADE335i
              • Apr 2013
              • 1385
              #111
              my car has been running reliably now for about a year.
              Engine:
              M30B35 from an '89 535is with ECU
              e30.de type 2 engine mounts with new rubber mounts
              e30 318i flywheel
              e34 535i starter
              Australian Clutch Service Xtreme organic clutch and HD pressure plate for 318i
              Getrag 240 5 speed with urethane mounts
              e32 Aux fan triggered by e28 82 degree aux fan switch in thermostat housing
              Modified exhaust manifold with flange turned 90 degrees to add clearance to steering arm, 2.5" exhaust with hi-flow cat, sport resonator & muffler.
              Suspension:
              Noltec adjustable strut tops
              Whiteline offset urethane CABs
              Eibach Pro Kit
              Bilstien B8s
              Final Drive:
              3.73
              15x7 wheels with 205s.
              Future plans:
              Getrag 260, single mass e28 flywheel & 240mm clutch (already acquired) for if / when the G240 breaks.
              284 cam, Miller MAF / War chip & BTB e30 M30 headers - when the car starts feeling slow again, which isn't a problem at the moment :)
              My e30: OEM+ with M30B35
              • F34R
                sLaughter
                • 12376
                #112
                M30b35 from a 1989 535
                260/6
                SETA complete drive shaft
                I made mounts to put the engine 2" into the firewall
                Mishimoto Rad
                3.15LSD
                Shifter is an e30 alum arm with UUC evo 3 bottom guts with a Z4 lever.
                E30 Condor Speed Shop engine and transmission mounts.
                M50 raceland headers with the flange removed and heated/bent to m30 blank flanges.
                Custom 2.1/4" dual from headers to a Y 2.5 inlet and a 3" outlet to a Magnaflow 3"in and 4" outlet muffler.
                Engine was completely resealed and powdercoated.
                Instagram: @BWeissLeather
                Current cars:
                ~ '87 325 M30B35 swap
                ~ '87 535
                ~ 01 540 Msport 6spd
                ~ '06 X5 4.8is
                • LowR3V'in
                  • 4209
                  #113
                  Pics or ban pls.
                  • lukeADE335i
                    • Apr 2013
                    • 1385
                    #114
                    Here ya go :)
                    Fitting engine
                    Engine Bay - one year on!
                    Outside (not overly keen on the rims but they were free with new tyres - I normally run stock 14 inch weaves for that ultimate sleeper look :) )
                    First Start
                    On Dyno - 124kW @ the wheels on the day; most importantly fuel ratios etc. were spot on, as were driving tests - stoich on cruise, WOT enrichment working etc.
                    • schofield
                      • Jun 2013
                      • 3
                      #115
                      Hi Everyone, i have found a '89 535i manual, which is breaking and i am after the engine and box (which is for a good price) can someone put a list of what i will need from the above vehicle? for the swap into a '93 e30 316 touring?
                      I roughly know but i don't want to miss anything as it is a 8hour drive away?
                      All help will be appreciated and i will be starting a build thread as soon as i have the engine + box.
                      Thanks
                      • jimbom30cab
                        • Oct 2013
                        • 1
                        #116
                        M30 cab
                        A few pics of mine, completed this summer
                        • marshallnoise
                          • Sep 2013
                          • 3148
                          #117
                          Beautiful work man. :)
                          Si vis pacem, para bellum.
                          New Hawtness: 1995 540i/6 Claptrap
                          Defunct too: Cirrusblau m30 Project
                          Defunct (sold): Alta Vista
                          79 Bronco SHTF Build
                          • F34R
                            sLaughter
                            • 12376
                            #118
                            This spring I am going to finish tucking wires and make a shroud for the intake.
                            Current cars:
                            ~ '87 535
                            ~ '06 X5 4.8is
                            • superboosted
                              • May 2012
                              • 667
                              #119
                              ^so nice... I plan to be in this club in under two weeks..Just sourcing bs right now.Wish i lived closer to one of you guys,It would help me to just look around in a swapped bay.
                              • F34R
                                sLaughter
                                • 12376
                                #120
                                You're from PA, you are welcome to come look my swap over. Any questions just shoot a PM.
                                Current cars:
                                ~ '87 535
                                ~ '06 X5 4.8is
