My 333i Swap: The beginning
  • chadthestampede
    • Jul 2008
    • 3601
    #46
    I got the engine in and hooked up, and I connedted everything, turned the key AND.........click. I think my starter is bad :(
    Originally posted by LJ851
    Feedback
    • euroshark
      • Apr 2006
      • 3491
      #47
      Not necessarily. The C103 plug is a toughie, and if it's not correct you won't be able to start the car. Before you go after the starter, test for voltage on the center pins of the MAIN relay with the key in the "on" position. From there test for voltage at the starter. Just trying to save you some grief.
      Way to make it to this point though! You are almost done with the hard stuff!
      • chadthestampede
        • Jul 2008
        • 3601
        #48
        Alright, thanks...maybe it's because I don't have the e30 c103 wires going anywhere. I couldn't find anything to match them up with so I didn't connect them to anything. in hindsight, maybe that was a bad idea...
        Feedback
        • Funkmasta
          • May 2004
          • 7185
          #49
          keep us posted... oh, and don't forget pics!
          Joe Funk -- Portland Oregon
          That Guy.
          03 X5. 3 liter obviously.
          • chadthestampede
            • Jul 2008
            • 3601
            #50
            Alright, well I figured out the starter plug (BL/YW) was on the wrong plug on the starter, which makes me feel like an idiot but I'd rather feel like an idiot than have an excessively complicated wiring issue.
            As of now the engine turns over but does not start, so thats the next thing I'm addressing.
            Oh and I promise I will get some pics, it's funny the pictures have been becoming fewer and fewer as my pace picks up and I get more excited about merely finishing the swap!
            Feedback
            • euroshark
              • Apr 2006
              • 3491
              #51
              Ok, since you have rotation and no start you need to confirm you are getting fuel and spark. Fuel is easy, you can have someone listen or touch the pump while you crank, or you remove a fuel line and stick it in a bottle. Spark is simple too, just remove one spark plug wire, put an extra plug in it, and ground the plug against the engine or chassis while cranking (be careful, you might want to wear gloves). My bet is no spark, and I bet the reason is the main relay. If it turns out that this is the case you can jump the main relay and have a running car in a matter of minutes.
              Edit: After reading your post about the C103, you will need to wire it up BUT I'm still betting you will need to jump the main relay. PM me and I'll send you details.
              • SpecM
                • Oct 2005
                • 4531
                #52
                haha yeah I realized that the other day, but I didn't feel like editing the first post...but which ones were turbo? I could swear I read an article somewhere about a turbo 333i.
                -theres a turbo 335i
                -but its an e90
                1989 cirrisblau-metallic 325i
                • chadthestampede
                  • Jul 2008
                  • 3601
                  #53
                  I believe I am getting fuel, but I am not getting a spark. The ignition coil gets power but no spark. I've checked the main relay (i think) and replaced all the relays with ones that I know work from my e30...The only thing I can think of is it has something to do with the flywheel sensors (since b32's are flywheel triggered) I think my flywheel might not have the little doohickey that sets of the sensor...that's what I'm guessing, since I bought the flywheel seperate
                  Feedback
                  • euroshark
                    • Apr 2006
                    • 3491
                    #54
                    Returned your PM.
                    • chadthestampede
                      • Jul 2008
                      • 3601
                      #55
                      alright, i realized that i did not have the green wire going into the c103 on the harness connected, which is the one that goes from the non existent obc for the engine to the main relay. I connected to the green wire coming from the c101 in the e30, which according to the etms is the same wire coming from the obc and the ignition switch which will cut the power if no circuit is made.
                      I'm currently charging the battery and im going to see what happens when I'm done.
                      Feedback
                      • Funkmasta
                        • May 2004
                        • 7185
                        #56
                        What is your flywheel out of?
                        That Guy.
                        • The Barvarian
                          • 162
                          #57
                          Nice progress..
                          "Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting...Holy S**t!! What a Ride!!"
                          • chadthestampede
                            • Jul 2008
                            • 3601
                            #58
                            Apparently the flywheel is the stock flywheel from a 533i
                            Feedback
                            • Funkmasta
                              • May 2004
                              • 7185
                              #59
                              if it is from a 533, you have the pickup sensors
                              That Guy.
                              • euroshark
                                • Apr 2006
                                • 3491
                                #60
                                The green wire with the orange plug looks more like an ABS sensor or airbag connector. Not sure about the little brown / green yellow connector...
                                You need to get the ETMs for the year of your E30 and the year and model this engine came out of. They will help you figure out what goes where on the C103 which still seems like your problem area.
