Considering M30 swap
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    #31
    maybe we can put that into my shell.
    • kronus
      • Apr 2008
      • 13032
      #32
      Originally posted by Jean
      I can only answer your diff question, and that's a yes. I changed my small 318i open diff for a medium case s3.73 and it bolted right up.
      The A/C compressor is about in the same position, but I believe you'll need to get custom lines made, i plan on having A/C in my car with b35.
      Also, there were more than one style/type of g260 trannys.
      Good, new lines shouldn't be too big of a deal. I have too much invested in that compressor to lose it now...
      Thanks on the diff. Now to fire a PM off to Carbon-Farbon.
      the g260 I speak of is the one in my eta, with extra holes in the bellhousing for sensors.
      cars beep boop
      • kronus
        • Apr 2008
        • 13032
        #33
        Meh, screw PM'ing you :P
        If you're serious, I want your trans and your driveshaft.
        cars beep boop
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          #34
          It's all yours, as I've said during many of our late night rendezvous.
          • accident
            • 7303
            #35
            Originally posted by kronus
            RealOEM does not seem to have a e28 section :(
            Click 'Archive'
            Also: if you need someone to help turn a wrench I am so in.
            Moral of this story?
            • JoeMadoo
              • 936
              #36
              ^^^im down too.
              '86 E30
              '05 E53 X5
              '72 Firebird
              '10 Prius
              '03 Tundra
              • kronus
                • Apr 2008
                • 13032
                #37
                Awesome. <3 you guys.
                I guess a first step would be to find someone with a truck... I somehow don't see transporting an M30 in my backseat being too simple to take in/out.
                Farbin, do you have an engine stand and a cherry picker?
                Engine mounts are paid for and on their way :D
                cars beep boop
                • BenM
                  • 2184
                  #38
                  Not to get you down, but did you get the mounts for the B34 (Gen II) Motor, since it sounds like you are using that. The B34 block has the bosses for one of the motor mount arms (drivers or passengers side, I can't recall) in a different position than the B35. Also, in addition to the proper motor mount arms, you also need the B35 Oil Pump & Oil pan, since the B34 items will not properly clear the E30 subframe.
                  Another point is that you cannot use the B35 flywheel since the B34 has specific teeth in it for the Reference sensors with the Motronic 1.0 Electronics, like that in your ETA.
                  While the motor is out, you should do the oil pan gasket, valve cover gasket, rear main seal, thermostat & waterpump. This is good preventative maintenance. The M30 is robust enough that I wouldn't worry about the Timing Chain failing.
                  Another thing to check while the valve cover is off is the bolts holding the oil sprayer bar. They tend to come loose, and you should replace them and add some locktite for good measure.
                  Another tidbit, is E28 radiators can be had for around $200 new right now, so that may be another way to go and ensure a fresh cooling system, along with the pre-mentioned thermostat & waterpump.
                  HTH.
                  Originally posted by BillBrasky
                  E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
                  1991 318i Alpine II - S50/5-lug swapped - track car
                  1989 325i Cirrusblau - Daily
                  1970 2500 - Malaga over Grey Cloth
                  2012 F350 6.7PSD
                  • kronus
                    • Apr 2008
                    • 13032
                    #39
                    The mounts I got are e30.de Type I mounts, which are for the B34.
                    I am aware of the B35 pan and pump being necessary. However, the way I heard it, I will need the pan from an E34, no exceptions. Can I use the E32 pan?
                    cars beep boop
                    • Funkmasta
                      • May 2004
                      • 7185
                      #40
                      HTH.
                      And always do the dist cap and rotor before you put the motor in!
                      Joe Funk -- Portland Oregon
                      That Guy.
                      03 X5. 3 liter obviously.
                      • Funkmasta
                        • May 2004
                        • 7185
                        #41
                        E32/E34 535/735/M5 all have pans that you can use.
                        That Guy.
                        • kronus
                          • Apr 2008
                          • 13032
                          #42
                          Yep, got a new set lying around. (as far as I know, M20 and M30 cap/rotor are the same)
                          cars beep boop
                          • Funkmasta
                            • May 2004
                            • 7185
                            #43
                            True
                            That Guy.
                            • BenM
                              • 2184
                              #44
                              Good call! forgot those two....
                              2012 F350 6.7PSD
                              • kronus
                                • Apr 2008
                                • 13032
                                #45
                                Looks like I will be putting in an order for a whole bunch of seals and gaskets to Pelican sometime in the next month.
                                Hmm... I might as well get a new clutch while I'm at it, right?
                                cars beep boop
