Low oil pressure when warm/m43 turbo
  • HCompain
    • Oct 2023
    • 8
    Hello everyone. I'm building a m43b19 turbo, it's pretty much the same platform with m42 and m44. It came stock with balancing shafts, wich i deleted so the engine would be a bit more responsive, and have a bit more oil pressure because the balancing shaft bearings are fed w/ pressure.
    When i start the engine, the pressure is at 3 bat on idle, wich is normal if the oil is cold, and it creeps to 5/6 bar when given revs.
    When the engine warms up, the oil pressure drops to 1 bar on idle and creeps to 2.4 bar when given revs.
    After driving a bit hard, the oil pressure drops to 0.3 bar at idle and do not exeed 1.5 bar when given revs... Seems way too low for me
    I'm running 10w60 and i added a thickening bottle hoping it would help with the pressure but it did not.
    The engine has been rebuilt, so new crank/conrods bearings.
    Maybe the oil gets too hot? Won't be suprising as i'm feeding a turbo
    Thanks for any advice.
  • 82eye
    • Jan 2009
    • 2095
    did it get a new or upgraded oil pump when the build happened ?
    • HCompain
      • Oct 2023
      • 8
      I switched to a better looking oil pump from a part out engine, because mine had a bit of scoring
      • 82eye
        • Jan 2009
        • 2095
        did you shim the pump to increase the pressure ? you may need to revisit that.
        • Panici
          • Dec 2009
          • 2550
          Agreed that warm & hot pressures are concerning, especially running a 60 weight oil.
          Those oil feeds that went to the balancing shafts, are they wide open now or did you plug them?
          • e30davie
            • Apr 2016
            • 1788
            What sort of restrictor is in the oil supply to the turbo? Wonder if its losing all its oil through the turbo.
            • HCompain
              • Oct 2023
              • 8
              I plugged it so i don't think it's the issue here.. i'm getting an oil temp gauge to see if it's the problem here
              • HCompain
                • Oct 2023
                • 8
                It's not a ball bearing turbo, so no restrictor, and previously i had sufficient oil pressure w/this setup. Now i'll be looking for a oil cooler setup as i see it's a bit more complicated than i anticipated on there m4x engines.. thinking about a plate w/two an fittings where the oil filter housing bolts to the engine and relocate the filter.
                • Panici
                  • Dec 2009
                  • 2550
                  Good idea.
                  Speaking of gauges, how are you reading oil pressure currently?
                  If electric, you may want to buy a mechanical gauge just to verify your electric gauge is reading accurately.
                  • HCompain
                    • Oct 2023
                    • 8
                    Good idea.
                    I thought of that but when the engine is cold it reads 3 bar on idle and i doubt it would be more than that but if i don't see anything wrong i will check that.
                    • HCompain
                      • Oct 2023
                      • 8
                      So update, today i installed an oil temp gauge and the oil warmzd up steadily to reach 100° wich is wayy below my expectations! But shortly after i tried to increase the boost pressure to 0.8 bar and my stock headgasket didn't liked that..
