No start, stranded.
  • Danny
    • 14216
    Can you hear the pump prime?
    • freeride53
      • 11972
      man, fuck this. I spent an hour walking to the local auto store, bought a fuel filter, spent a while installing it, and it started up. it would not hold an idle, kept fucking dying. Then I started it, and got it 1/4 mile from my house, going to the nearby gas station to fill it up. Shit dies again. Had to push it home, being honked at by people, causing traffic, and ran over my toes.
      And Danny, I cannot really hear the pump over the sound of the engine, schreeching, and the exhaust. Are you referring to the typical buzzing sound?
      1983 Peugeot 505 STI
      1992 Volvo 240 Wagon
      • trackjunkie21
        • Jan 2010
        • 3962
        check if you are getting spark and fuel, if not then it's the main relay. When that goes bad it shuts off both fuel and spark. If you said that you have power going to the pump, but no power coming back that means the pump is fried. Time for a new one.
        Originally posted by Wh33lhop
        VANOS: sometimes you just need to go full retard.
        • freeride53
          • 11972
          the car ran for a 5 minutes. then it died, and wouldn't come back. And all that time, it was running TERRIBLY, it sounded like a fucking Harley.
          • Danny
            • 14216
            No, when you turn the key to the on position, does the pump prime the fuel lines?
            Can you hear the pump kick on?
              • 34844
              stock BMWs only turn on the FP when the ECU sees a crank signal, they don't prime it. the FPR is supposed to hold rail pressure constantly.
              • Danny
                • 14216
                Really? I could always hear my stock pump kick on when I turned the key to the on position and even more so when I had my Walbro 255.
                • freeride53
                  • 11972
                  depression bump :( Still no start. check my lines, amongst other things, and still no go.
                  • Fraser
                    • 198
                    Have you checked fuel pressure? It still doesn't seem like you've ruled out a simple bad pump... It turns on when you jump the relay, or not?
                    325iX Turdbo Rally/Hillclimb/Beater
                    • Schnitzer318is
                      • Jan 2008
                      • 2057
                      Mine "primes" quite loudly as well Danny. I think m42 cars do this but m20 ones do not. My m20 cars pump can not be heard (or felt because they run quiet compared to m42 ones) until cranking. I just replaced an m20 one that was faulty so I am sure on this.
                      As for the OP... check your pump. If your car worked when the guy hit the tank, you pumps little plastic "filter" thing on the pickup could have fallen off and gunk got into the pump causing it to go bad. Just happened to my convertible's pump. Super easy to pull these pumps, swapped mine out in 15 minutes.
                      "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                      91 318is Turbo Sold
                      87 325 Daily driver Sold
                      06 4.8is X5
                      06 Mtec X3
                      05 4.4i X5 Sold
                      92 325ic Sold & Re-purchased
                      90 325i Sold
                      97 328is Sold
                      01 323ci Sold
                      92 325i Sold
                      83 528e Totaled
                      98 328i Sold
                      93 325i Sold
                      • M42Power
                        • Dec 2009
                        • 519
                        Check your auxiliary belts and alternator ect.
                        Might be the source of the screeching and the smell. Might have seized something
                        Originally posted by kendogg
                        Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
                        OG RACECAR
                        • trackjunkie21
                          • Jan 2010
                          • 3962
                          If it idles like crap check to see if you have a vacuum leak under the throttle body. Those hoses always go bad.
                          • nrubenstein
                            • 3148
                            The screeching noise is your fuel pump after it ingested a masss of glop from the bottom of the tank. Replace it. The good news is that the stock trunk tool kit has everything you need to change it.
                            2002 BMW M3 Alpinweiß/Black
                            1999 323i GTS2 Alpinweiß
                            1995 M3 Dakargelb/Black
                            - S50B32/S6S420G/3.91
                            1990 325is Brilliantrot/Tan
                            1989 M3 Alpinweiß/Black
                            • freeride53
                              • 11972
                              screeching noise is from the bay for sure. It comes whenever I rev it.
                              Cliffs: I bought an Alternator belt, A/C belt, and a P.s. belt. Gonna tackle it when I get home. screeching came before the car went bad, for the past two months or so.
                              ....btw, the car failed SMOG a week or two ago, and the tester mentioned a loose vacum hose or something of the sorts. I'm growing restless now, and really wanna fly home to fix it!
                              • Atreus
                                • 1846
                                check to see if youre getting
                                fuel
                                spark
                                then go from there. should be easy enough, do that first. check your cap and rotor? that could have been that sound as the rotor spun around bouncing back and forth inside.... i dunno...
                                1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                                1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                                1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                                1991 325iC - Calypsorot Metallic
                                1994 540i - Granitsilber
                                Originally posted by scabzzzz
                                I've had blunts cock in my mouth, but I'm not gay.
