Which diff ratio for M42?
  • Cal
    • 38
    I'm about to put an LSD in my car. Would you go a 4.1 or a 4.45 and why? Sounds like it might buzz a bit too high on the highway with the 4.45. It's hell slow with the 4.1 though.
  • tjts1
    • May 2007
    • 1851
    • Dj Buttchug
      • Jun 2010
      • 7686
      dude no way. 4.10 is way quick. top speed sucks if thats what you mean. imo it depends how you drive.
      I have a 2.93 in mine. the long gears are great for crusing
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • tjts1
        • May 2007
        • 1851
        Having to shift to 3rd gear before 60mph makes the car feel slow in the real world. It can handle taller gears no problem.
        • e30huh
          • 216
          there's a 3.46 for M42 for sale on the local craigslist.
            • 34844
            the top speed of an M42 powered car probably doesn't change or goes down with an excessively long rear diff ratio.
            E30s are almost *never* gear speed limited. I don't get why people think a 4.10 or higher makes the top speed lower. I also don't understand the desire to go 120mph in 3rd gear..
            • 2002maniac
              • 4260
              I think 4.10 is the best for street use. 3.73 is sluggish and 4.45 is screaming on the highway. I've tried them all but would like to find a 4.27 to try out.
              Nando, i redlined my m42 in 5th with the 4.10. It took a while to get up there though.
              • Supadave
                • 1006
                slow on the top end or the bottom? I have a 4.10 lsd in my car, its great the only complain i have is high rpm on the freeway, wich really isnt that bad. With a 4.45 lsd would be sick doing autoX. I guess it all depends on your driven style and hp. Me myself would like a 3.73 when I'm done building my stroker.
                https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
                • tjts1
                  • May 2007
                  • 1851
                  Perfect.
                  Why you would want be forced into 3rd gear before 60mph is beyond me.
                    • 34844
                    I'm not. my 2nd gear goes to a hair over 60mph. ;)
                    a 3.73 isn't bad and makes sense. but a 2.93? Those are smogger gears..
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      Don't forget that he has boost
                      Originally posted by Wh33lhop
                      VANOS: sometimes you just need to go full retard.
                        • 34844
                        so? 2.93 is still retarded. how about a 3.25 or 3.55? What does 5th gear top out at with a 2.93, 200mph? What's the point of that? Why not convert to a 3 speed automatic while you're at it? :p
                        • Supadave
                          • 1006
                          Are going to stick with the 2.93?
                          • tjts1
                            • May 2007
                            • 1851
                            With a 4.10 diff, not unless you're revving past 7300. And you speedometer is way off.
                              • 34844
                              Yes, yes, and no. It's dead on actually - verified with a direct VSS input to the ECU. ;)
                              but my tires are a little oversized. if they were stock size, the dash speedo would be about 4mph high. the ECU speedo wouldn't care though.
