Which diff ratio for M42?
  • Cal
    • 38
    I can't believe some of you are suggesting longer gears. These things are a slug with 4.1
    • greanthumb
      • 1992
      +1^^^^
      91 318is...DD:finger:/85 325es SOLD/91 318is RIP
      Originally posted by naplesE30
      Must stop clicking on Norwegian threads. Makes me wanna punch my car in da mouf.
      Originally posted by einstein57
      My tranny sounds like a blender full of walnuts. So I added sound deadner to the tunnel and put in a louder stereo. Am I doing it right?
      Castro Motorsport/E30 specialist
      North Hollywood, Ca. 818 310-2497
      • SimplyDope
        • 1335
        I didn't find the change to the 3.73 to be as dramatic as some of you are making it out to be. If you do any driving on the highway, it's a step-up from the 4.10 in my opinion.
        It has slightly less "snap" acceleration-wise, making it feel more like a normal car, but it's definitely not sluggish and I personally love not having to change gears so quickly. I honestly wouldn't be surprised if 0-60 times improved.
        • KenC
          King of Kegstands
          • 14396
          Who the hell cares about 0-60? News Flash: you're going to lose to that Accord next to you at the light.
          I just popped a 4.45LSD into mine a few weeks ago. I like it better than the 4.10. It's a little peppier. RPMs only went up 2-300 at freeway cruising speed.
          As mentioned before, these cars aren't gear limited.
          Originally posted by Gruelius
          • Wh33lhop
            • 11705
            No, they're a slug with M42s. Different gears aren't going to change that. ;)
            paint sucks
            • Dj Buttchug
              • Jun 2010
              • 7635
              Originally posted by nando
              the top speed of an M42 powered car probably doesn't change or goes down with an excessively long rear diff ratio.
              E30s are almost *never* gear speed limited. I don't get why people think a 4.10 or higher makes the top speed lower. I also don't understand the desire to go 120mph in 3rd gear..
              uhh wut? how does it not change the top speed? you install a longer gear it will give a greater top speed, shorter gives lower top speed last time i checked...
              Originally posted by Supadave
              Are going to stick with the 2.93?
              for now yes. I am an exception to most because im boosted. more power changes things, especially when you want to have time to build boost instead of having to shift all the time.
              srsly? race an accord at a light? cmon now
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • Wh33lhop
                • 11705
                It does if you have enough power to wind out the top gear. Most M42s do not.
                paint sucks
                  • 34827
                  yeah, are you hitting the limiter in 5th gear? no? then you're not changing your top speed with a shorter diff. You might actually lower it with a taller one since the car will no longer have enough torque in 5th gear to push through the air at high speed.
                  and it WILL take longer to get there. aside from shifting times (you still have 5 gears so it doesn't change that), a shorter diff will accelerate faster than a taller one. it's basic math..
                  • M-technik-3
                    • 18946
                    Originally posted by e30huh
                    there's a 3.46 for M42 for sale on the local craigslist.
                    http://washingtondc.craigslist.org/n...058727263.html
                    E36 lsd....different than an E30.
                    • revhard7
                      • 38
                      i have a 4.27 on my m42, i think its the best compromise for street use and its responsive on the highway, longer gearing ratios would kill it..
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        honestly, with the stock motor, a 4.10 is about right. Any shorter and it would get to be a pain, and any longer and the poor thing would be even more of a gutless wonder in daily driving. It just isn't practical to wind the motor up to higher RPM to spin a taller diff in daily driving to get the same performance out of it. I'm going to a 3.73, but that is only because of the turbo, and I'm doing a lot more highway driving than I used to.
                        Project M42 Turbo
                        • gsxrcop
                          • Apr 2008
                          • 161
                          I'm a little confused, a boosted m42 can make more power than alot of swaps I have seen. Not all m42's are created equal :)
                          "No, they're a slug with M42s. Different gears aren't going to change that."
                          • Wh33lhop
                            • 11705
                            Right, but 99.9% of M42s are not boosted. You can turbo anything and make it quick.
                            paint sucks
                            • Schnitzer318is
                              • Jan 2008
                              • 2057
                              In my boosted car I went from the 4.10's to the 3.73's and HATED it. Took longer to build boost and "felt" slower. It might be a tad faster from 0-60 because of one less shift... but other times it is ALOT faster because of the decreased boost time.
                              That's been my experience anyway... ymmv.
                              "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                              91 318is Turbo Sold
                              87 325 Daily driver Sold
                              06 4.8is X5
                              06 Mtec X3
                              05 4.4i X5 Sold
                              92 325ic Sold & Re-purchased
                              90 325i Sold
                              97 328is Sold
                              01 323ci Sold
                              92 325i Sold
                              83 528e Totaled
                              98 328i Sold
                              93 325i Sold
                              • Dj Buttchug
                                • Jun 2010
                                • 7635
                                maybe im confused as well... I dont know why but i love the 293. If you want it quick use lower gears. all your really doing is moving 100 whp in most m42s around some. Shit even when I was on a stock motor I ran a 293 from a 410 and loved it.
                                it all comes down to how you want to drive. Ive got multiple diffs so if im not feelin the longer 293 I swap to a 410.
                                After you swap diffs a few times you get good at it. I can do a diff swap in less than 20 min...
                                Ig:ryno_pzk
