typical head machining prices
  • b*saint
    • 3794
    What does it usually run to mill the head and regrind all the valve seats and new valves? As well as press out and press in the new valve guides. Roughly. 500 bucks?
    Ma che cazzo state dicendo? :|
  • rjcaptsean
    • Jul 2009
    • 51
    I just pulled my head and had it tested and machined.
    I pulled the cams myself, so that saved about $100. (If you haven't done it, I highly recommend some research as they are hollow and break very easy.)
    Pressure tested, two exhaust valves replaced @ $16 each, all others reground (I provided new seals) and machined all for $402.00 Only slightly more than half of what I paid for the entire car. :drink:
    • ///digitalme
      • Dec 2009
      • 2088
      Should be 400-500. I got two estimates from two machine shops when i f* my engine. With new valves it was 550. If I would provide parts it would be 400.
      Anoter shop said 600 for everything. Si think 400-600 range would be it.
      • Dj Buttchug
        • Jun 2010
        • 7688
        seems a little high. i got a full refresh with port and polish for 400
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • rasjgo1
          • Aug 2011
          • 332
          Where u located
          Sent from my SGH-T999L using Tapatalk
          • TobyB
            • 5298
            I don't think M42 cams are nearly as fragile as M52...
            Around here, $600 would be a good deal.
            t
            • I8UR911
              • Jan 2013
              • 260
              $800....pnp head, 3 angle valve job, new valve seals and valve guides, complete clean and slight resurface..... not enough to significantly change CR.
              Sent from my SCH-I535 using Tapatalk
