Air bubbles in my oil! No oil pressure.
    • 34844
    Originally posted by Vtec?lol
    cool. would it be the same if i remove the plugs and force the Vaseline up the pickup tube while cranking?
    no.
    the air is inside the pump, that is the problem. if you put vasoline in the pickup tube it's just going to clog it.
    • Vtec?lol
      • Dec 2009
      • 3278
      damn this sucks.
      • Ryann
        • 3350
        Good idea. now to rig something to shoot oil.
        When I'm building an engine at home I use a power steering fluid hand pump that I found at an auto parts store. It's the same one I use to replace my trans. and diff. fluid actually.
        • Vtec?lol
          • Dec 2009
          • 3278
          You mean the one that you put on top of the bottle and push down to pump? good idea
          • Dj Buttchug
            • Jun 2010
            • 7686
            whatever you do dont use vaseline. use engine assembly lube.
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • Ryann
              • 3350
              Yup.
              • Vtec?lol
                • Dec 2009
                • 3278
                Thanks asschug (love your name lol) and ryan!
                • rob_e30
                  • 456
                  We just had this problem and solved it by priming the pump. There is an additional fitting on the side of the oil filter housing that faces the front of the engine. That leads directly to the pump. We use it for fitting a pressure gauge sender. Remove this fitting (allen head I believe), use a hose and funnel to pour some oil down there, turn the crank by hand (it should take some oil).
                  • trackjunkie21
                    • Jan 2010
                    • 3962
                    How are the bolts on the top oil pan? If they are loos the pan will shift letting air get sucked in.
                    Originally posted by Wh33lhop
                    VANOS: sometimes you just need to go full retard.
                    • Vtec?lol
                      • Dec 2009
                      • 3278
                      UGH! AWESOME! I'm going to check this as soon as I get home!
                      thank you thank you thank you!!!!!
                      Shouldn't be the case as everything was torqued to spec. I will check anyway thogh. thanks
                      Thanks for all your help guyss!
                      • Vtec?lol
                        • Dec 2009
                        • 3278
                        Ok, just tried to pump oil in that little hole but got nothing. I tried cranking it with the hole just to see if any would shoot out and it did but still nothing. I turn the crank over and over by hand while pumping and plug the hole up then bam. nothing.
                        • Dj Buttchug
                          • Jun 2010
                          • 7686
                          this one yes?
                          just for reference because
                          Ig:ryno_pzk
                          • Vtec?lol
                            • Dec 2009
                            • 3278
                            ^yes that one.
                            • rob_e30
                              • 456
                              That's the one.
                              • Vtec?lol
                                • Dec 2009
                                • 3278
                                I've done it countless times and nothing. I'm f**ked
