M42 fotostory, as requested
I'm Actually doing research on m42 parts in regards to boosting it. I'd love to be able to pop the hood and have a top mount turbo just staring at me :D . I'm might order my stuff from VAC motorsports, I've heard they are too pricey but from the looks of it their products look top quality.Comment
Explain please ... Specific to certain parts or what?Parts Collector and Former Houndstooth interior junkie.Comment
I'm not going to say what specific parts, as there are many, nor do I want to dis either company. But if you do the work that they've done (e.g. measuring sizes and figuring out the specific mechanics of different things) you can find some of the same things they offer for cheaper. Hell, you can call Metric Mechanic and they might tell you a few things that you're local machine shop can do instead of shipping parts to them.Comment
Thats kind of a bummer to hear that. I want to stay away from ebay as much as possible as far as engine parts go. I want to find a decent vendor that I can stick without throught the whole build, so that way they know what I've purchased and could help me find other parts I need.Comment
well.. you're doing it right in my book..
props mate..Comment
How well do the ITB's match the ports. I find allot of people just slap ITB's on and think that is it. When in reality it could be possible that they are not much better then the stock manifold.
As for parts from VAC they are a distributor there prices will always be more then what you can get if you were to go strait to the supplier. But you pay for the customer support that they offer, which is more important then others.
So are you running with the M44 crank larger pistons? What will your displacement be? What will be your max rpm?Last edited by Massimo; 04-19-2012, 07:17 PM.sigpicComment
VAC and MM are both good, I (and others) have found their offerings for cheaper thru extensive web searching. If I were to get CatCams, I would definitely go thru VAC.
So are you running with the M44 crank larger pistons? What will your displacement be? What will be your max rpm?Comment
I didn't check the port matching, but it is obvious that the ports on the head don't match the lower intake just from looking at the gasket. You can also see where the stock injector spray pattern constantly washes the mismatched portion of the intake ports on the head. This is my daily driver and I am in a hurry to get it back on the road.
Well I think your goal of 160whp should be no problems. Can't wait to see the out come.
I also see you are going to spin the cast crank up to 7.5-7.8. I want to see this. If all gose to plan I might look into keeping my stock forged item and trying to go for 8.5 maybe 8.8. depends on oil starvation and solid lifer optionsLast edited by Massimo; 04-19-2012, 09:39 PM.sigpicComment
About time someone show the M42 some respect. WELL DONEFEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
Who cares. The stock m42 intake ports are so choked up by valve guide protrusion and the aluminum around them that it probably doesn't matter. In your case dBilas are about throttle response and audio feedback.Comment
Funny you and I have pretty much the same build in mind just went mostly vac parts. I just need ITB's and I have 279/276cams at 11.5/10.95mm the lopes pretty well I make great power up top on track, but would die for a set of those dbilas to free up my top end. My engine sees about 7-7.5 all day on track with issues so far. I'm making 142rwhp at 2400ft elevation(and feels like a lot more at buttonwillow need a standalone). I also don't have pistons or a single row timing chain and I kept the m42 forged crank(crank has been nitrided).
My next step would be solid lifter/pistons/rods/intake. That would be a mighty fine hp/L.1991 BMW 318is Track Car-NEEDS ITBS AND STANDALONE!!
1997 BMW 328i Daily Driver-like buttah..Comment
any pics of your car on here? Hearing about more and more ppl putting work into their M42's, makes me want to keep mine.Comment
