M42 Whine issues
  • Ryann
    • 3350
    It's the input shaft bearing in the transmission. When you depress the clutch pedal it disconnects the input shaft from the engine, and the noise goes away.
    • JRYE30
      • Sep 2011
      • 465
      Ya, thats sounds like it could be my issue. I'll try and get a video up today...see if that helps. It seems to 'wind' up and down with acceleration
      1987 325 | @e30_hunter |
      • TobyB
        • 5263
        I suspect you're hearing 2 different things, but try MTL in your transmission and see if
        it quiets down. You're hearing ALL the gears when you're in neutral, and they're unloaded.
        For some reason, that sometimes makes them LOUDER, not quieter.
        High speed whine in my experience is usually the diff.
        And some noise at high speed is a sign that it's older- but not necessarily dead yet.
        But if your trans is dry, then I bet I'm wrong!
        t
        • TimKninja
          • 2131
          My trans had 265k on it. It whines terribly even when topped off with fluid. All the same symptoms as yours but i bet mines worse.
          You can hear my tranny over my exhaust. I can hear the
          Syncros work when i put it in first while rolling .
          Its a common thing with getrag 240s . They arnt built nearly as well as 260s.
          1985 325e M50TU(Sold)
          1991 318is Slicktop (Sold)
          1990 325is Brilliantrot S50/5 Lug Swapped.
          1992 525i Manual shitbox Winter Beater
          • ///digitalme
            • Dec 2009
            • 2088
            pilot bearing or throwout bearing mine does the same thine im waiting for the clutch to go out to install the new one waiting to go in
