Interest in Bolt on Turbo kit?
The basic is what's your set up, my old set up was a internally wastgated t3 turbo, running 16psi, a rrfpu, stock dme, and I can't remember what injectors I hadOriginally posted by ErickDude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.Comment
TD04-15g internal WG
NXS Signature Manual boost controller
9psi
running a bosch recirculating valve
42lbs injectorsComment
With Jake's tune you will need to recirculate the BOV. Since it uses the stock AFM pre-turbo, it's already metered the air and will go very rich once you're off throttle. It would probably still work vented to atmosphere, but would likely die when downshifting or coming to an idle from higher RPM.Comment
Maybe that's why it backfired everything I was off throttle.....since I didn't build the motor I ended up lifting the head since the guy I bought the motor from didn't use Apr studs like he told me.....Originally posted by ErickDude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.Comment
Where do you recirculate it to?With Jake's tune you will need to recirculate the BOV. Since it uses the stock AFM pre-turbo, it's already metered the air and will go very rich once you're off throttle. It would probably still work vented to atmosphere, but would likely die when downshifting or coming to an idle from higher RPM.
-NICKComment
Is it plummed to line coming out of the compressor?? Not seeing how that would work otherwise.
-NICKComment
