Interest in Bolt on Turbo kit?
  • jntar
    • 459
    #376
    Originally posted by PFCRayB
    I apologies in advance for not reading though the whole thread since I'm on my phone but are you offering the dme separate?
    He does offer a turbo chip separate. I am running it in my turbo car currently. PM him and he will give you details.
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
    • PFCRayB
      • Nov 2009
      • 403
      #377
      Do you mind if I ask a few questions on your car
      Originally posted by Erick
      Dude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.
      • jntar
        • 459
        #378
        Ask away.
        M42 turbo build.
        • PFCRayB
          • Nov 2009
          • 403
          #379
          The basic is what's your set up, my old set up was a internally wastgated t3 turbo, running 16psi, a rrfpu, stock dme, and I can't remember what injectors I had
          • jntar
            • 459
            #380
            TD04-15g internal WG
            NXS Signature Manual boost controller
            9psi
            running a bosch recirculating valve
            42lbs injectors
            M42 turbo build.
            • PFCRayB
              • Nov 2009
              • 403
              #381
              I had a 1g dsm bov
              • jntar
                • 459
                #382
                I had a 1g dsm bov
                With Jake's tune you will need to recirculate the BOV. Since it uses the stock AFM pre-turbo, it's already metered the air and will go very rich once you're off throttle. It would probably still work vented to atmosphere, but would likely die when downshifting or coming to an idle from higher RPM.
                M42 turbo build.
                • PFCRayB
                  • Nov 2009
                  • 403
                  #383
                  Maybe that's why it backfired everything I was off throttle.....since I didn't build the motor I ended up lifting the head since the guy I bought the motor from didn't use Apr studs like he told me.....
                  • Balleristic31
                    • Aug 2009
                    • 4198
                    #384
                    Where do you recirculate it to?
                    -NICK
                    • jntar
                      • 459
                      #385
                      Back in pre-turbo/post AFM.
                      M42 turbo build.
                      • thomas88162
                        • Dec 2013
                        • 4
                        #386
                        Originally posted by jakeb
                        You are not that far away...come up this summer and I'll make a manifold off your car.
                        ...You are certainly tempting me.
                        • bmwm42
                          • 6300
                          #387
                          Could you post a pic I'm also buying the chip separate
                          Originally posted by bmwm42
                          PNW vulture pm me for parts
                          Strategic nw e30 command
                          • jntar
                            • 459
                            #388
                            Old turbo with same diverter valve setup.
                            M42 turbo build.
                            • Balleristic31
                              • Aug 2009
                              • 4198
                              #389
                              Is it plummed to line coming out of the compressor?? Not seeing how that would work otherwise.
                              -NICK
                              • jntar
                                • 459
                                #390
                                Yes, it's connected to both the intake side and compression side.
                                M42 turbo build.
