a bit of clarification on M20 flywheel/clutch conversion
  • bflan2001
    • Sep 2007
    • 65
    #61
    It isn't, the stock m20b25 flywheel is something like 18lbs whereas the 323i flywheel is 13lbs. I don't know if they are the same dimensions. I just remember that the parts I collected were, at the time, supposed to be the only way it would work, but from reading through this thread I can see that's not the case. Unfortunately I'm still having trouble making sense of it all.
    • bmwman91
      • Oct 2004
      • 3128
      #62
      Well, one thing that you can do is take the full M42 clutch/flywheel assembly out and measure thisknesses of the stack-up. Then do the same for your E21/E30 M20 assembly. See how close they may be. Looks like you are going to get the privilege of being everyone's guinea pig with this!
      Transaction Feedback: LINK
      • bflan2001
        • Sep 2007
        • 65
        #63
        Well I guess I am due for a contribution of my own. I'll dig all the parts out and get things measured up this weekend.
        • jwal
          • Apr 2014
          • 385
          #64
          I hope I am not asking a dumb question...but does the m20 flywheel setup require a different pilot bearing? I am ordering all my parts and I am not sure how this change affects that decision. I know that the clutch alignment tools only work for particular bearing sizes, so it would be nice to know definitively which bearing to use. Thanks
          • ForcedFirebird
            • Feb 2007
            • 8300
            #65
            Pilot matches the trans. To use a g240, use a m42 pilot. Spline count is the same, so the tool will work fine.
            john@m20guru.com
            Links:
            • jwal
              • Apr 2014
              • 385
              #66
              Ok great, that makes it easier :)
              Thanks firebird
              • roguetoaster
                Biggus Tippus
                • 7826
                #67
                Be aware that if you are using an M42 G240 there are two different pilot bearing sizes.
                • jwal
                  • Apr 2014
                  • 385
                  #68
                  Yeah, I saw that too. Just one more thing to check I suppose
                  • brads2002
                    • Nov 2005
                    • 2688
                    #69
                    yes the M42 bearing has a wider center so while the M20 tool will fit the spline it will not work to align it correctly.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #70
                      Not all of them. ;)
                      The time you would need a different tool would be if you changed your transmission since the bearing has to match the trans. A lot of kits don't come with the tool.
                      john@m20guru.com
                      Links:
                      • roguetoaster
                        Biggus Tippus
                        • 7826
                        #71
                        Exactly. For reference, two different M42 G240s, although it's a bit hard to see the comparison:
                        • brads2002
                          • Nov 2005
                          • 2688
                          #72
                          Interesting. I didn't know there were 2. Mine has the larger one for sure.
                          • jwal
                            • Apr 2014
                            • 385
                            #73
                            I am going to measure mine so I can know for sure. I hope its the larger one so the m20 clutch tool fits :P
                            • jekas619
                              • Apr 2014
                              • 2
                              #74
                              Hi
                              Welcome to this forum site, here u can find lots of thing. I suggest u for your problem, you have to contact your friends. I am not able to give u answer right now sorry for that
                              Top Ten classified website
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #75
                                Getrag 260 has the small diameter bearing.
                                john@m20guru.com
                                Links:
