whoever figures this out...100 bucks paypalled to them..
  • bmwman91
    • Oct 2004
    • 3134
    You only need to remove the valve cover to check.
    If it was running properly, pulled out of the donor car and put straight into yours, then it probably is not the timing.
    Transaction Feedback: LINK
    • MF DOOM
      • Apr 2012
      • 944
      are you sure all your sensors are plugged in correctly? No two are swapped?
      • CHIF8008
        • 3447
        double check everything. again, dont just assume you have it right the first time
        -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
        -The Beauty in the Tragedy-
        MECHANIC SMASH!!- (you all know you do it)
        Got Drop?? ;-)
        But of course
        E30s are know to be notoriously really really really ridiculously good looking
        • FLG
          • Sep 2011
          • 3165
          Spark plug wires on the correct cylinder?
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • AlphaE
            • Sep 2011
            • 503
            Posted this in ur other thread as well. I may be crazy but sound like ur exhaust is plugged. Runs enough to build pressure, can't get rid of pressure, dies, pressure leaks back through intake and air filter. Need vid. What's this boom? Like backfire? Sound mechanically related not electrical. Cam timing is off. Exhaust valve hung up,exhaust system plugged. Something along those lines.
            Now with 2.7i power!!!
            • timofeylbelarus
              • Dec 2010
              • 326
              i've had something like that too the car cranked but didn't start after i put everything together, came out to be i hooked up the coils the wrong way, when i put them the right way it fired right up
              1985 325e - wrecked :( (being fixed and full paint job)
              http://www.r3vlimited.com/board/showthread.php?t=197989
              the horrible day
              http://www.r3vlimited.com/board/showthread.php?t=210850
              1991 318i - in process of being made a DD
              http://www.r3vlimited.com/board/showthread.php?t=219793
              • lateralfx
                • Feb 2013
                • 4
                When I did my swap I had the same problem. Turns out I had the coil pack plugs backwards. As soon as I swapped it around it started right up. I felt pretty dumb to mix that up. Took a few hours to figure it out too. But it was a simple fix. My 1-2 were in 3-4 it was 180 off
                • broach328
                  • Nov 2009
                  • 296
                  yeah I was gonna say this ^ either you could have the coil packs/plug wires out of order, theres a mechanical issue with the cam timing, or possibly a tappet issue(valve is hanging, causing possible backfire when it dies out. I have experience a similar issue before and it was timing related. What happened was, it would start and sound very rich and hardly idle. If you opened the throttle body at all, it would die out and it made a large detonation into the intake manifold similar to how your describing. In my case, it was a 24v motor and it blew the ICV off the intake manifold and did no other damage. In your case, it might have blown the intake manifold gasket or cracked the manifold or maybe even no damage at all. First of all though, I would check that coil packs are all hooked up properly on both the engine wiring harness to coils and in order from coils to spark plug. If those are in order, I would then check the cam timing. If that isn't your problem, run a compression test to make sure valves, hg, etc are all operational. Get back with us after that but its more than likely one of those issues.
                  • wazzu70
                    • Jan 2005
                    • 1143
                    This. Make sure the coils are plugged into the correct plug. If you get this mixed up the ignition timing will work, just at the wrong time. The bang at the end when turning the car off is an obvious sign.
                    I did this when swapping in my M42. Thought for sure I had them plugged in correctly, but I had two switched.
                    -Nick
                    M42 on VEMS
                    • broach328
                      • Nov 2009
                      • 296
                      Yeah, and those aren't numbered for some reason so you have to trial and error
                      • irish44j
                        • 2763
                        you can use a multimeter and measure resistance from the DME pinouts to each individual coil to determine which coil wire goes to which cylinder. There's a pinout chart in the Bentley. Put the multimeter on the dash inside the windsheild - it should be able to reach the DME and the coils if you have reasonably long leads.
                        This worked like a champ in determining which one of my wires were which, since they weren't marked from the previous owner of the engine that I swapped in.
                        Stage rally/rallycross e30 build/competition journal
                        Track/street e21 build
                        visit Condor Speed Shop
                        visit Motorsport Hardware
                        [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
                        • VANOS714
                          • Nov 2011
                          • 1195
                          anyone get the $100?
                          • CreamBeam
                            • 223
                            I agree with AlphaE this does sound like it could be related to an extremly plugged up exhaust or damage to an exhaust component like the valves,cat,etc. good luck
                            • kwill22
                              • Apr 2009
                              • 962
                              I say timing. Check crank TDC mark and the Cams TDC and make sure they're right. If not Lock flywheel in place and do the timing yourself to make sure. The crank can be easily rotated 180 and the car will still run but will not be happy.
                              DENY IGNORANCE!
                              Schwarz 325-totaled
                              brilliantrot 318i-daily
                              Originally posted by mkcman17
                              don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
                              • broach328
                                • Nov 2009
                                • 296
                                did you ever reach a verdict?
