Ugh, how bad is it? (M42 in pain)
  • Wschnitz
    • 8089
    It burns oil on start, goes through coolant, and wont stay running.
    I checked for leaks and I'm only seeing a really tiny coolant leak, looks to be coming from the front.
    willschnitz
  • lolcantturn
    • 4588
    youve been on this forum since 2011 and don't know about a compression test? geeze
    Originally posted by TSI
    OEM+
    • chance
      • Feb 2012
      • 671
      I would say the profile gasket is toast. Might be a cracked head.
      I have an m42 for sale btw
      1991 335is in progress
      • Dj Buttchug
        • Jun 2010
        • 7686
        just pull it out and fix it already. fuuuu
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • AndrewBird
          The Mad Scientist
          • 11898
          Due to the fact you are going through coolant and oil, I would say a blown head gasket. Do a compression test and that will tell you.
          Is there any oil in the coolant or coolant in the oil?
          • Wschnitz
            • 8089
            Oil seems to be staying at a fine level, Its the coolant I'm losing.
            I plan on doing a compression test.
            willschnitz
            • Wschnitz
              • 8089
              What is the Stock compression per cylinder in an M42?
              willschnitz
              • wazzu70
                • Jan 2005
                • 1143
                Hes asking if the two are mixing. Your oil will look more like a milkshake. Drain the oil and see if you get coolant/water coming out of the pan. Its easy to tell if thats the case.
                You can also get an exhaust gas analyzer kit at the parts store which you put on your coolant expansion tank. If the exhaust gasses are in the coolant, the liquid inside the tester changes color.
                Overall, sounds like a head gasket issue to me.
                -Nick
                M42 on VEMS
                • Dj Buttchug
                  • Jun 2010
                  • 7686
                  you should see no less than 150 psi on each cylinder. An accurate reading can be had in 5 full revolutions of the engine.
                  Ig:ryno_pzk
                  • iamsam
                    • Jun 2008
                    • 176
                    cool story bro time:
                    So my M42 started eating coolant, and belching gargantuan smoke clouds in mornings, and I finally ended up getting around to taking the oil out of the M42 and it looked like this:
                    No, that is not a picture of what happens after three big macs and a mountain dew with no nearby restroom. That is the actual material that chugged forth from the oil pan drain.
                    So I summarily sallied forth and removed the head gasket only to find myself befuddled at the lack of any obvious gasket failure. The old gasket looked perfect.
                    So i slapped in a new gasket anyway, put it all back together, and to my dismay, it still ate coolant every morning for breakfast on the way to work.
                    So I deduced that the head was warped, and decided to put in an M20, since fixing the M42 would have been far more expensive.
                    And I lived happily ever after!
                    • lolcantturn
                      • 4588
                      ^well why would you go through all that trouble of replacing the HG on a DOHC engine and not even check if the head was straight? ;) every cylinder head warps
                      OEM+
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        Cool story with pics, boo to the M20 (although innovative).
                        OP you probably have a cracked cylinder head, it happens, get a new one (head or engine) and move on. First check should be to pull the plugs to examine them for poor combustion, second check should be to look into the cylinder bores and look for a pool of coolant in cylinders 2 or 3.
                        Good luck, don't give up!
                        • iamsam
                          • Jun 2008
                          • 176
                          yep, I shoulda done that, but in my hurry and stupidity, I did not. I was trying to get to a rally event in time, but I should have put that off. Either way, M20s are better for rally...
                          • iamsam
                            • Jun 2008
                            • 176
                            also: I do have a spare M42 head in my garage (recent acquisition, post M20 swap) that is for sale...
                            • Wschnitz
                              • 8089
                              Cylinders 2 and 3 didn't have pooling coolant or oil in the cylinders, but there was a little coolant where the spark plugs were.
                              willschnitz
