Quick question: bolt torque spec
  • Violet88
    • Jun 2010
    • 435
    Hey everyone, was seeing if someone could help me with this, these four bigger bolts that hold the alternator and bolt onto the block, what's their torque spec? The alternator isn't the lightest thing so I don't want them too loose, and then again my worst nightmare is to strip a bolt, I found the specs for the oil filter housing right next to it, just cant find this one, thanks guys
    '88 325i cabbie royal blau
    '91 325i cabbie calypso rot
    '92 318i cabbie laguna green
    ~I like all my b!tches topless ;-)~
  • Dj Buttchug
    • Jun 2010
    • 7686
    those go into the cast iron block. You will have a fun time trying to strip those. Just get them snug and then 1/4 turn past that and your good.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • jntar
      • 459
      I couldnt find the answer either and I just did this today. I used 43nm for the m8 bolts.
      M42 turbo build.
      http://www.r3vlimited.com/board/showthread.php?t=301330
      • Dj Buttchug
        • Jun 2010
        • 7686
        the rule is if the hardware goes into aluminum chances are its 10-15 lb feet. if the hardware threads into cast iron its not so specific unless its head bolts
        Things like alternator brackets and AC brackets just need to be tight.
        Ig:ryno_pzk
        • 10Toes
          Me Father Was A Tree
          • Jan 2008
          • 61222
          I beleave those are 8X1.5 (check and see) and look like they say grade 8.8, probably do about 17 ft lbs
          There are lots of general torque charts online like this one.
          • LJ851
            • 7919
            8X1.25 bolts (12 or 13 mm wrench size) generally are 24Nm ish or 17 ft lbs as 10Toes expertly recommended. Aside from his thread pitch being loco.
            Lorin
            The M30 is God's engine.
            • jntar
              • 459
              Sounds like I should go back and re-torque the bolts I just did :(
              M42 turbo build.
              • 10Toes
                • Jan 2008
                • 61222
                Your right, it's the M10's that are 1.5
                • TobyB
                  • 5286
                  unless it's fine thread... which it wouldn't be, going into cast iron...
                  (says the man who's trying to work on a toyota 2f...)
                  t
