Fresh m42 top end rebuild
  • irish44j
    • 2763
    Originally posted by Bmr
    So i moved the exhaust gear back one tooth and now it sits flush with intake and lined up in the middle. Also i see a lot of write ups where the timing tensioner is compressed. Why is that when you can push in with oil uncompressed and not risk jumping a tooth.
    I wish I had a serious answer, but the answer is "because it won't"
    Does the car run better now?
    Stage rally/rallycross e30 build/competition journal
    Track/street e21 build
    visit Condor Speed Shop
    visit Motorsport Hardware
    [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
    • Bmr
      • Jul 2009
      • 322
      Had to gr some Sealant and more coolant because of that damn plastic cooling connector. I should have the car running a couple hours.
      Sent from my SGH-I317 using Tapatalk 4
      • irish44j
        • 2763
        the pipe off the block? Did you crack it or something?
        • Dj Buttchug
          • Jun 2010
          • 7686
          fwiw i always install my tensioners in a fully expanded state. never had an issue
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • irish44j
            • 2763
            ditto, I've never had any problem pushing it in and getting it threaded...
            • Bmr
              • Jul 2009
              • 322
              Not cracked, for some reason it seemed to be slightly twisted. Fixed and put some silicone around. No leaks now. On another a good note since that slight adjustment on cams last night, car is so smooth and purs. It's been along time its sounded this good. haha
              I have never done the tensioner the compressed way. I had a friend lecture me that i could mess up my timing, basically thought a bout it and couldn't figure out how it would have.
              I put the 19mm wrench on, then push with my other hand, seems to do the trick.
              Since the car runs so great now i cant decide if i should sell my flywheel clutch setup or use it. It's a JB racing 8lb flywheel with kevlar stage 2 clutch. I keep having second thoughts because of hearing about the rattles. But then again if i sell it i could buy a MarkD chip.
              • Dj Buttchug
                • Jun 2010
                • 7686
                id consider selling it. Theres really no reason to have such a clutch on a mostly stock engine. Driving around everyday you are going to want a stock or more mild clutch setup.
                Ig:ryno_pzk
                • Bmr
                  • Jul 2009
                  • 322
                  That's my feeling, this clutch was previously on a m20 that was free flow exhaust, headers, 19lb injectors, gasket matched head, cammed and chipped with maf conversion. By no means is my 318 even close to that. haha
                  • Dj Buttchug
                    • Jun 2010
                    • 7686
                    see the real problem with a gnarly clutch and a super light fly is that like you said before you get really interesting chatter, the clutch has no modulation whatsoever and its really a bitch to daily drive.
                    Ig:ryno_pzk
                    • MF DOOM
                      • Apr 2012
                      • 944
                      ^^^ Id sell it.
                      or make use of it and boost the m42 :up:
                      • Bmr
                        • Jul 2009
                        • 322
                        Originally posted by MF DOOM
                        ^^^ Id sell it.
                        Well then made my mind up then. Sell stuff and get started on turbo stuff. I spent around 1800+ on my m20 to get to 200hp, i bet i can spend 2k and get more from this m42.
                        • MF DOOM
                          • Apr 2012
                          • 944
                          Youre going to sell the clutch and then turbo? You should check out the kit jakeb makes. Nothing but fantastic reviews from it. And if youve seen any of the other builds that he has done then you know the quality of his work.
                          • Bmr
                            • Jul 2009
                            • 322
                            That is exactly what i was planning on doing. Wish people would buy my parts dang it.
